Can subframe connectors be installed...
On a car that is stripped down to this level? I really don't want to wait until I get it all put together because I want to paint the underbody...
Oh, the the doors and windsheild have been removed since this picture was taken, and the body seam welded...
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, definitely. It's probably the best time for it.
Ed
Ed
Sweet, thanks! I figured I should brace it as close to where it will be sitting stock so it doesn't bow the way it does a little with the jack stands on the frame so near eachother. Is that a correct assumption? Anything else I should do?
Thanks again,
Douglas
Thanks again,
Douglas
Car: 1983 Trans Am
Engine: 305 LG4
wait!
Doesnt the car have to be under suspension,?
Wouldnt the best time to connect the subframes be when all the tires are on and the springs are compressed?
I wouldnt weld them on right now to be honest
Car: 2002 Formula Firebird
Transmission: 4l60e
I have always heard the car has to be loaded and have weight on the tires. I have no idea what I'm talking about so don't listen to me. Just thought I'd keep the post alive.
You should be fine. I know I've seen pictures of Spohn's first SFCs installed on a bare frame. IMO, I don't see a difference in installing them with the suspension loaded or not if the frame is straight. I believe this is done so the suspension doesn't have to be readjusted; it just avoids some extra work. If you weld them onto a complete car without the suspension loaded, you'd probably just end up having to get the alignment checked. The only thing I would do is have the body checked for straightness with GOOD equipment and then weld away.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
One easy way to tell if the car is tweaked funny is by opening the doors. Easy to open? Will they shut easily? If so, then the SFCs can be welded fine. If you find that the door wont latch or there's an odd thud when opening or closing, then don't weld and try to relocate the jack stands.
Well, the doors are off now, however, when they were on they shut very nicely. Well, as long as the latch didn't somehow shut off the car, then it really didn't want to shut at all.
Car: '91 TA vert
Engine: turboLSx
Wait...
Is that an evo kit in your av? Do you have an evo kit?! If so I want to come up there and take a look at that!
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by iansane
Wait...
Wait...
Wait...
Wait...
i was actualy just looking at that kit today on the web
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
well can these be welded in place with the car on jackstands (not stripped down) just fine? im doing some serious work this winter to her and i want to have the subframe conectors and a roll cage installed now.
but to be honest i dont even konw how to install them....all i have is two competition engeneering pieces of tube steel with a bracket on one end of each. anyone wanna help out?
I don't have a really good set of doors for it, however a set of doors was on it when it was almost at this stage, I think the windshield was all that was left, and they shut just fine then, so I wasn't too worried about them not shutting properly.
Car: 4
Engine: 6
Transmission: 5
Yes they can be put on in that stage, there's no reason not to. The suspension doesn't have to be "loaded". All that has to happen, is to make sure the car is straight.
The body sheet metal does not care what state the springs are in during the process; or even whether they're there or not.
I had mine put on with the body in about that same condition, with it bolted to a race car chassis jig.
Here's somebody that did it that way.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
