C4 brake question/experiences
Old May 27, 2004 | 11:24 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Hey. Altough I have had my C4 brake upgrade from Ed for over 1 year I only have about 2000-3000 miles on them.
First my review........They were easy to install, and after I put them back on my brakes never fade, but here is the problem.
They are hard!!! Hard as in you gotta really push em to get them to stop and this was even as soon as I put them on(ie before they sat and got any kind of build-up or film on them. ) Sometimes it seems the harder you push does not do anything more.
I was wondering what pads, yall are using on your setups to give it a better feel.
Chris
Old May 27, 2004 | 02:47 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
could be a bad booster master cylinder or they might just need a good bleed. check that out but if you are using a harder pad that might have a little to do with it but I dont think it should make your breaks that stiff
Old May 27, 2004 | 05:26 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Chris. I did notice a firmer pedal but not a hard one, at least not as you described it. Did you swap out the master cylinder for the disc/drum (J55) master? If not, I'd do that. That's what the 1LE cars use and those are the same calipers essentially.
Ed
PS: I still want the rearend, I'm just a bit busy lately...in the hospital having a baby. I hope it's still available.
Old May 28, 2004 | 01:02 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
1LE uses the disk/drum master?
That is what I have.
Yep the rearend is still in the car!!
Chris
Old May 29, 2004 | 12:40 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You mean J65 for the drum mc. J55 is the C4 13" brake option
[edit] Oops, ment to say J50 for drum, not J65.
Old May 29, 2004 | 01:21 AM
Re: C4 brake question/experiences
Because of the different amount of piston area compared to the 1 piston caliper, they give a bit firmer pedal. It shouldn't be too drastic, just noticable. I use Hawk HPS pads. Seem pretty good.
Old May 29, 2004 | 02:52 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Actually, it's J50 for the disc/drum/1LE master cylinder. J65 was the disc/disc mc until 1990 when GM decided to use the J50 for all F-body models.
The bigger brakes should grab better. My 1LE brakes made a major improvement in m how my car stops. The pedal feels about the same, maybe a tad firmer, but the car stops with ease. I'm using the EBC Greenstuff pads in front with Hawk pads in the rear.
The big problem I have is that the '88 rear discs can't keep up with the 1LE fronts and I have too much front brake bias.
Old May 29, 2004 | 03:24 AM
Doh! You are correct. To many numbers floating around
Old May 29, 2004 | 07:43 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've got Ed's C4 brakes too. Though I haven't logged too many miles on them (less than 2K) I haven't noticed a harder pedal since they were installed back in January,just the firm pedal that it's supposed to have. My car is a 90 and came with disc/drums so I have the J50 MC everyone is referring to.
Old May 31, 2004 | 08:26 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
does ed sell c4 break kits?? what type of pricing is there?
thanks
-Tony
Old Jun 1, 2004 | 06:59 AM
Mongoose's Avatar
Car: 90 Formula
Yes he does. Prices start at $550 for a C4 kit but you get $50 back when you send him your old spindles.
Old Jun 1, 2004 | 08:38 AM
Dr G's Avatar
thanks
-Tony
Tony, send him a quick email or a pm and I'm sure he'll give you all the info you require. He's very good to deal with.
Old Jun 1, 2004 | 08:50 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
thanks for the info fellas...
Old Jun 1, 2004 | 08:03 PM
Mongoose's Avatar
Car: 90 Formula
Here's a pic of them installed.
Attached Thumbnails C4 brake question/experiences-new-brakes.jpg
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
