need to redo frint end, i know nothing, help
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
my camaro's front end is thrashed. i have spent all my time on the motor, and now this needs attention.
all the knowledge i have gained is motor related, and aparently i need a new topic. i hope this goes as well as my swap.
what parts are replaced on a wore out front end? (i.e. parts list)
is Spohn the best place for replacement parts?
which parts are not offered by a high performance manufacturer?
any help would be awesome.
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
if you are just doing the front end, Spohn has a complete front end rebuild kit that is made by MOOG, Spohn throws in their own adjustable tie-rod sleeves that they powdercoat red. this kit plus the master bushing kit from Energy Suspension is all that is needed for a front end rebuild unless you plan on doing the a-arms as well.
most of the part replacement is pretty straight forward. read your manual, look at your car then ask specific questions. you need to be extra careful dealing with coil springs and you need to have the right tools to do the work with.
Engine: 5.7L TPI
does your car have the coil-over springs? if it does, do as ede said and get the right tools. you will need a coilover spring compressor in order to get them out if you are even going to mess with the springs. be careful with the springs as they may try to grenade out of the car when you have them compressed with the tool.
There are no stock coil-over setups on thirdgens. If you are replacing the springs and struts up front, you need a spring compressor or some creative jackstand/lift skills. Typically, a front-end rebuild includes the steering components and bushings up front, but if those springs and struts are shot, you might as well do them too.
I also recommend Spohn's rebuild kit. Steering components aren't all that hard to replace, but you will need an alignment when you're done. A complete front end rebuild includes the following:
everything in Spohn's rebuild kit
struts + springs
upper strut mounts
front sway bar end links and bushings
front spring isolators
wheel bearings and seals
Optional but highly recommended:
subframe connectors
wonderbar
Optional:
a-arm bushings
engine and trans mounts
steering box
brakes (rotors, pads, calipers, stainless steel flex lines)
strut tower brace
18" Boyd Coddington wheels
That should cover everything. If there's anything I forgot, let me know.
struts + springs
upper strut mounts
subframe connectors
wonderbar
Optional:
a-arm bushings
steering box
strut tower brace
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
