which sfc???
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
which sfc???
Which subframe connector is best used on third gens?
I have a buddy that has mac subframe connectors, And he has a really big problem with clearance issues. I would like something that will have alot of ground clearance so that in the future i can lower my car and still be abil to go over a speed bump well.
I dont mined the price to much, please get back to me asap.
-Eric
-Eric
Transmission: 4L80E/4L80E
The Spohns I got fit up higher than the exhaust.
Weld-in are typically considered superior to bolt-in.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
spohns here. Welded in quite easly (except that brace around the cat). Doors open and closed easier. Noticed less body flex.
From my readings, if you plan to drag it, get boxed. Daily use/auto-x, you want round.
Engine: 5.7 tbi
Transmission: t5
I want to drag but not too much, will drag just to now what it is doing. But will drive daily, and i am really into drifting, so more for that. So what do I should use?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
I got a set of Alston's and love them. East to install, and just look stronger than most I have seen.
And, Alston is GREAT if you have any questions...great tech support....
80's AL:rockon:
80's AL:rockon:
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
If you dont like the MAC clearance YOU WONT LIKE ALSTON... they are the same design except Alston bolt on and mac weld on...
BTW I have for sale a set of new MAC sfc's...
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
