spohns sfc's and spohn swaybars
Old Jun 3, 2004 | 04:24 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i'm trying to improve the cornering ability of my 2.8 ltr camaro , i've already decided to get some spohn sfc's but i'm wondering if i should also get the spohn 36/24 swaybar kit aswell?
is it to much for my car, or should i go with 34/22 ?
i already have a wonderbar and am goping to get a stb aswell
any insight would be appreciated
Old Jun 3, 2004 | 09:40 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Determining proper sway bars can get complicated. There are many factors that determine what the proper sway bar is. If you can, the best way to get the combo right is to just simply experiment. However, that is damn near impossible in the real world. It would be very timely and expensive to test and tune all the possiblities. Having said that, I would say your best starting place would be to search on the boards for similar cars. There used to be one member with a 2.8 liter camaro that had a lot of suspension work and tuning on his car. Try to find out what other people with similar setups as yours have to get an idea of what is known to work well. Then go shopping.
Also, I don't really think using anything from a top notch company like Spohn or Hotchkis would have a negative effect on your ride. Hope this is helpful...
Old Jun 3, 2004 | 09:52 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well since i live in the city i do ALOT of cornering , and while my car is better then others i want to make it the best i possibly can at conering
Old Jun 3, 2004 | 10:41 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
you can run a larger rear bar than the V8's without lifting the rear. I run a 34mmsolid front, and a 25mmsolid rear bar. I also have much heavier springs rate that stock though. This controls front to reaar weight transfer as well as side to side. With stock springs I would recommend using 30mm front, 23mm rear for a balanced feel front-to-rear in proportion to side-to-side.
Old Jun 3, 2004 | 11:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
my biggest problem is i don't know if my shocks are stock or not and i know my cars been lowered
Old Jun 4, 2004 | 01:42 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
search for posts by AGood2.8 hes banned now, but spread much knowledge on the suspension board in his time
Old Jun 4, 2004 | 01:57 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Old Jun 4, 2004 | 07:11 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
v6 here, 34mm hollow GM and 24 solid GM.
Old Jun 4, 2004 | 07:34 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
before you put the sway bars on, your money is better spent getting some good shocks/struts.
a car with stock bars (with poly bushings) and shocks will out corner a car with badass bars and worn shocks.
Old Jun 4, 2004 | 07:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
my shocks are in excellent shape thats why i'm not upgrading them first
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
87camaro87
Sep 9, 2015 10:29 PM
