PBR Guys
Old Jun 17, 2004 | 12:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
PBR Guys
My non-1LE rear discs had a small spacer per side. Do the PBR brakes also have these or should I simply ignore them?
JamesC
Old Jun 17, 2004 | 01:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have no spacers on mine, and everything fits fine. 87 (I think - 1 stripe) IROC wheels.
Old Jun 17, 2004 | 03:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you are talking about the .187 thick spacer on the rear and you now have disc brakes just get rid of them. They were used on early drum brake cars with 16" aluminum wheels. If thats what you have just sell them on e-bay.
Old Jun 17, 2004 | 03:45 PM
JamesC's Avatar
The spacers have been a topic before. I had four-wheel discs "with" the spacer. GM....
JamesC
Old Jun 17, 2004 | 05:12 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
My '88 non 1LE rear discs had no spacer. As you know I have them now. If you dont' want your spacers, I'll take them tho.
Ed
Old Jun 17, 2004 | 08:55 PM
JamesC's Avatar
Ed and al.,
I finally completed the swap today. While the brakes and e-brake function fine (all was set up according to the manual), there's a bit of slack, say, two rachet clicks of the cabin's e-brake lever, before there's any tension and, of course, before the e-brake functions. I wonder if the 1434 cables are a bit longer. Any advice?
JamesC
Old Jun 18, 2004 | 06:12 AM
ebmiller88's Avatar
Did you try to tighten it up by adjusting the mechanism under the car in the trans tunnel? On your '85, it should look like this. Just tighten the nut until you like it. I had to go about an inch to get mine tight. You can see the clean threads where I made my adjustment:
Old Jun 18, 2004 | 07:07 AM
JamesC's Avatar
Ed,
Are you saying you're currently using spacers on your rear discs?
JamesC
Old Jun 18, 2004 | 04:17 PM
ebmiller88's Avatar
At the moment, yes.
Ed
Old Jun 18, 2004 | 04:24 PM
DJP87Z28's Avatar
Why are you using the drum brake spacers on 9-bolt disc rear???
Old Jun 18, 2004 | 04:41 PM
ebmiller88's Avatar
Oddly enough, they were on the '89 disc rear I installed, so I just put them on. I'll probably take them off next chance I get though.
Ed
Old Jun 19, 2004 | 06:25 AM
JamesC's Avatar
Ed,
Your suggestion about tightening the e-brake up worked well. I'll post pics of my transformation in the next few days (I hate reading and gathering parts all winter, only to finish the project in a blink of the eye!).
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
