should i replace it?
Old Jun 17, 2004 | 06:04 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
or does it seem normal? , i dont think a bend anywhere is normal
Old Jun 17, 2004 | 09:05 PM
2out_The_Left's Avatar
the tierod sleeve? if its bent then replace it. your going to have to replace it next time you go for an alignment anyways, it won't adjust if its bent. invest in the aftermarket sleeves, they have a much easier design to work with and will hold your alignment much longer then the clamp style stockers. they are also much thicker making them bulletproof compaired to the thin stock setup.
i use the hotchiks sleeves, 45 bucks from jegs. i know spohn offers them too.
Old Jun 17, 2004 | 10:20 PM
Car: 1990 firebird
Engine: 3.1 v6
alignment, see thats another thing that pisses me off about damn mechanics, the guy who did my alignment didnt tell me it would knock my alignment off, hell im sure he noticed it , alot of people have looked in that area and i think i was the only one who noticed it , guess im going to have to order it , is it safe to ride your car with a bent sleeve?
Old Jun 17, 2004 | 10:25 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You could still set the toe properly with the sleeve bent, but its shady and half assed. I have the Spohn adjusters. Either brand, if you are going to replace it anyway, get the beefer parts.
Old Jun 18, 2004 | 01:21 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
www.colemanracing.com
do a search and youll find part numbers for sleeves. i got mine for like $22 shipped
Old Jun 18, 2004 | 12:38 PM
Car: 1990 firebird
Engine: 3.1 v6
should i replace my tie rods while im at it ?
Old Jun 19, 2004 | 04:40 PM
its always good to have new parts. but if they are not broken or loose, there is no need to replace them
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
