a ? about modifying the sfc's (bolt-on)
Old Jun 20, 2004 | 10:07 PM
RICHRAD's Avatar
Can someone who's done this give me some help here...I've got the comp.eng. bolt-on sfc's and I'm wondering how bad a hack job the pass. side gets to allow the y-pipe clearance.. Is the cat.conv. out of the question now? .. Any pics greatly appreciated
Old Jun 22, 2004 | 10:38 PM
RICHRAD's Avatar
Decided not to use them. I'd rather not cut on them, but pass them on to someone with full length headers... They are new with hardware if anyone is interested... Competition Engineering sub-frame connectors #3111. $175 and $40- $45 to ship I guess (very heavy duty). can send a pic if your interested ..
Old Jun 23, 2004 | 09:30 AM
tyson__91's Avatar
Car: 91Z 99Z 68 SS
Hey i would be interested do they come with all of the hardware. E-mail pic's at tyson_utz@yahoo.com thanks alot.
Old Jun 23, 2004 | 11:32 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
my friend has them in his formula - they are surprisingly good and stiffened up the car unbelievably, but we had to modify them to clear the y-pipe - not the convertor.
Now he has the SLP headers and y-pipe in the car. The end where the angle is put in them is, we had to extend the angle. that was all we needed to do tomake them clear.
I say you make them work, they do a great job and they can just as easily be welded in to make them even better.
if your nearby to ct, i'd be perfectly willing to modify that spot to make them clear everything with no problems!
Steve
Old Jul 10, 2004 | 01:01 AM
RICHRAD's Avatar
Steve
Thanks Steve, but I'm far from CT. Not sure how you modified the angle there at the front pass.side. A pic or too would be great if possible. My hedman y-pipe comes nearly to the edge of the body and I can't see how it is possible to get around it... Rich
Old Jul 10, 2004 | 04:45 PM
fb305svs's Avatar
well i'll have to try and get a pic - he has the SLP y-pipe and like i said, he has ample clearence now.
basically all i did was extend the portion of where it is angled all the way to the end of the SFC (towards the front of the car)
this provided a ton of clearence, altho i will say, we did have to push the outer tube flat a bit from trying to get it to clear with out modding the sfc...
good luck, i'll try to get ya a pic - get back to me via PM sometime
Old Jul 10, 2004 | 05:10 PM
RICHRAD's Avatar
Ah-Ha! unuderstand better now...will look it over again..Yeah, I guess there where I extend it, it will have to be half the width cause that y-pipe is small enough as it sits....will check with you on a pic later then...preshadit
Old Jul 10, 2004 | 07:46 PM
fb305svs's Avatar
no problem, just remind me - got a lot goin on right now!
its really easy to do tho if ya got a cutoff wheel and welder and some flat stock... those were the only tools i used!
anyways, it makes it so the sfc tucks up against the floor pan and angles down to bottom - it left PLENTYof clearence on his setup, so i think you'll be good to go!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
