alignment: factory specs, or these...?
just got new tires (and rotors, and pads, and poly end links) and my alignment is ready for some refreshment! the shop i got the tires at would only set it to factory alignment specs, but i got some specs off this site that were recommended....
these are the ones i got off this site:
camber: L: -0.5 R: -0.5
caster: L: 3.50 R: 4.00 (or R as high as poss., L .5 less)
toe: L: 0.03 R: 0.03
my question: does anyone know the stock specs? i want to know how close they are to the ones above....and which i should get????
thanks
thanks
Car: Camaro
Engine: 6.2L
I have tried a few combos and like the toe to be right on 0.0 with .5 neg camber and about 4.7 caster and it works good. Not sure what the factory specs are anymore lol
Car: 4
Engine: 6
Transmission: 5
Those specs look good; except that the right camber needs to be a tweek higher than the left, like the caster; something like L -.5 degrees, R -1 degree.
Usually a little toe-in will help the tires stand up a little straighter when driving straight down the road; and will make the car feel like it has a more definite center. Just a little though: too much will make it scrub off outside edges.
Car: Camaro
Engine: 6.2L
Yeah I have a .3 difference on caster but I run camber the same. I have tried running camber variations all the way down to 2 full degrees negative and find the .5 to be a happy compromise to tire wear vs handling. I have had as much as .8 difference left to right but it still hunts a little in wavy roads regardless and I like the braking effect to be true so I equalized them and on hard stops I can let go of the wheel and it tracks straight.
Yeah toe in a tad will help "ease" the driving but it also adds a little resistance and tire heat so I run it at zero. It works for me but I seldom drive the car unless I am roasting it so I don't much mind the little extra effort
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I have the factory specs around here somewhere, I just got my tires aligned with them last week. I had a coupon for $39.99 at Suburban Tire which is the only reason I went there. I gave them custom alignment specs, but they wouldn't honor the coupon if I wanted to use my own specs, and I wasn't going to pay them $95 to use my specs when I could save over $50 by going factory. It's kind of bull**** that they would pull that though because its no different to them whether they use my specs or factory specs, its going to take the same time/work effort on their part either way. I should've threatened to leave and go to Just Tires...maybe then they would have given in :-/
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
You didn't mention exactly what car and what year....they're all different!
Anyhew, have a look at this page :
http://pageperso.aol.fr/sdgreyefdbv/...MENT+SPECS.htm
Si. :lala:
Si. :lala:
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
from this site:
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Code:
Q: What are the factory front end alignment specs?
A: With the stock Good Year 215/65R/15s, the settings were:
Caster +3 degrees +/- .5 degree
Camber +1 degree +/- .5 degree
Toe in .15 degree +/- .5 degree
Q: What are some suggested front end alignment specs?
A: A table in the Camaro & Firebird Perforamnce Handbook for 3rd Generation cars lists the following recommendations:
Caster Camber Toe Total
(deg) (deg) (in)
L R L R
Street +4 +4.5 -.5 -.5 3/32
Hard Street Use +5 +5.5 -1 -1 3/32
Drag Racing +4 +4 0 0 1/32
Road racing +6 +6 -1.75 -1.75 Short Course
1/8 out
Long Course
1/16 in
The figures are credited to Global West Suspension Components and are taken with driver weight included. Thread
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
gta892000
Sep 16, 2015 12:37 AM
