Eibach spring question?
Old Jul 5, 2004 | 06:00 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I installed a set of Eibach Prokit springs a month or so ago. My car then went in for some collision repair and paint. I have been driving the car for about a week now, and I have noticed that the RF sits higher than the LF by exactly an inch! The RF height is 25.75" measured on a concrete garage floor at wheel CL; the LF is 24.75". The rear is nice and level at 27" a side.
I know that springs require a settle in time, but its actually had over a month of sitting with the weight on them. I did also replace the LF fender with a fender off of an 88 RS my friend gave me. Would the the fender have been made differently causing an illusion of height difference?
Thanks for any help...
Old Jul 5, 2004 | 06:19 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
the fenders are the same!! 'you sure the bender didn't bend something else?
Old Jul 5, 2004 | 07:07 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
No, not sure. Any ideas as to how to tell??? I have not yet aligned my car because my exhaust sits so low I can't pull my car onto our alignment rack at work. Checking some of the alignment angles may shed some light. I am going to try to get that fixed tomorrow or later this week.
If you or anyone has any knowledge or what, where, and how to measure for squarness of the frame, I would appreciate the info.
Old Jul 5, 2004 | 08:05 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
The first time I installed my Eibachs I had the same problem. Did you do them yourself? Here is a link to ebmiller88's website where he clearly shows how to index your springs. I redid my springs as he shows and it's the correct height, both sides. If you're not a do-it-yourselfer, it may be difficult to get a shop to follow your explicit instructions...many think their way is right and you're the uneducated customer.
Anyway, on to the link... look at the picture I linked to, and the next two pictures (33,34,35)
http://f2.pg.photos.yahoo.com/ph/tar...&.dnm=6bcf.jpg
Adam
Old Jul 5, 2004 | 08:07 PM
Car: 89 IROC-Z
Engine: L98 - Stock
Excuse me, pictures 32,33,34 - opps
Old Jul 5, 2004 | 08:38 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Well, I was pretty careful to install the springs correctly. I will try to get it in the air at work tomorrow and see what they look like just to be sure! I made that mistake once already, the first time I installed lowering springs when I was like 17. This time, like all the times in between, I did as shown in the pics. Maybe they just need more time to settle in, or there may be some bendage from my previous accident. I will try to figure this out...
Thanks for the tips ya'll
Old Jul 5, 2004 | 08:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
By chance did the body shop remove them and forget to put back in one of the isolators? I would pull the short side and check them out. Indexing the springs is more important up front. There won't be a serious height difference if the rears are slightly off.
Old Jul 6, 2004 | 08:44 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I don't think so, but I will take a look see. Hopefully its just something small.
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
