anyone ? what clamshell required for spohn trq arm
Old Jul 7, 2004 | 03:10 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
recently purchased the spohn adj. trq arm with rear install kit. . . the tech said it ships with the forward busing, but for my '91 bird I'd need the correct clamshell to fit bushing 7-1609
anyone got a GM P/N for this ?
Old Jul 7, 2004 | 04:30 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
did you get the t/a with the crossmember as part of it, if so he was prolly talking about the tranny mount
see this link if it applys to you itll help a lot
link
if thats not what you have then you will have to change the clam shell t/a bushing and that is something i dont know, but you can find it in poly for sure, a few of the links at the top of the page carry them i think.
Old Jul 7, 2004 | 04:51 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
www.ws6transam.org/torqarm.html
Steve's adjustable torque arm relocates the torque arm mount off the transmission tailshaft and onto the transmission crossmember.
http://www.spohn.net/product.cfm?productid=1475
Full length transmission mounted adjustable torque arm for the 1982-2002 F-Body
Dont think this is the same piece. . . but, man -- thanks for that link -- awesome article !
Old Jul 8, 2004 | 06:10 PM
Engine: 350ci
does this help out?
poly bushing for 15$
if you want the gm rubber just go in with the clam mounts shell and ask for the part and check it for fitment, thats whatd id do.
Old Jul 8, 2004 | 06:15 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
What we have here is a failure to communicate
the torque arm ships with the 7-1609 bushing. . . what im looking for is the p/n for the clamshell that fits this bushing. Guess i'll try my local GM dealer.
thanks again thou
Old Jul 10, 2004 | 12:30 PM
Engine: 350ci
baaaaa hahahahahahaha
i am total dum ***
Old Jul 13, 2004 | 08:51 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
You can use your stock clam shell IIRC, Steve designed the bushing that is supplied with the tranny mounted torque arm, for a 84-02 app.
Kat
Old Jul 13, 2004 | 08:59 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
thanks, but I recently purcased the fourth-gen style mount from my local dealer -- and verified that this was the correct one with Steve.
Kat
If thats right, then not only did I waste my time & money -- but someone should tell Steve !
Taken from here
NOTE: 1982-1992 cars require the use of a factory torque arm bushing clamshell mount designed for bushing type 7-1609. If your vehicle is equipped with a 7-1611 type bushing -- which all thirdgens come with stock, you will need to get the 7-1609 type clamshell. (See below pictures
Old Jul 13, 2004 | 10:36 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
:shrug: I'll ask him tomorrow for ya
Kat
Old Jul 20, 2004 | 04:15 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
and the correct answer is . . .
Insulator = GM P/N 10252374
Outer Bracket = GM P/N 10252375
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
