Formula Rims
Old Jul 9, 2004 | 08:01 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
Formula Rims
Is it ok to rotate formula rims, or are they axel specific? I have rpo code ws6
Old Jul 10, 2004 | 01:19 AM
Greek's Avatar
Car: 1988 Firebird Formula
Engine: 5.0 V8 305 LB9
Front's go to the front and Rear's go to the rear.
The front rims should have a wider (bigger/thicker) "lip" and the rear rims should have a narrower (smaller/thinner) "lip".
Later,
Harry
Old Jul 10, 2004 | 06:28 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can get another pair of fronts to mount on the rear, that way you can rotate front to rear and it will give you a wider stance in the rears,
That is what I did with my 88 Formula,
Old Jul 11, 2004 | 11:43 AM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
so the front ones can work on the rear, and the rear ones would have trouble if mounted up front?
i ask cause i have a pair of formula wheels like that picture, and they both say front, and i wanted to put them on the rear.
Old Jul 11, 2004 | 11:53 AM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
Where does it say front?
Old Jul 11, 2004 | 12:03 PM
Engine: 350ci
inside the wheel
Old Jul 11, 2004 | 12:13 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
do you have to take the tire off to see this?
Old Jul 11, 2004 | 02:51 PM
Engine: 350ci
no tire removal is needed, only take the wheel off the car and look on the rear of all the spokes, you will see casting info and front or rear will be writen there
Zepher's Avatar
The rear wheels may rub the tie rods I believe. Fronts on the rear are fine.
Old Jul 11, 2004 | 02:59 PM
Engine: 350ci
sweet! now for cleaning and polishing and two new tires, maybe kumho? hehehe
88SS6SPEED
Nov 11, 2015 07:05 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:02 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
