1LE Brake Bracket Dimensions
Old Jul 14, 2004 | 04:20 PM
1985 406Z-28's Avatar
I was just wondering if anyone knew the dimensions for the brackets that go between the carrier and the spindle(hole locations, offset, hole size, and thickness). I have access to an abrasive water jet and would like to cut my own. Any help would be appreciated.
Old Jul 14, 2004 | 04:59 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I would also like that info.....been trying to find it for some time now. I can CNC them at work if I only had the part dimensions.
Anyone?
Old Jul 14, 2004 | 05:45 PM
Parrydise7's Avatar
Have you tried a search. This was a real popular topic maybe a year ago and there is a great deal of info. In particular, look for posts by ebmiller.
While the brackets are no longer available from a dealer, AFAIK those brackets are available from a variety of sources including Spohn.
Good luck.
Old Jul 16, 2004 | 08:47 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can make a set yourself but unless you have a really big bandsaw, a good drill press, and the steel, you'd be better off buying them from Steve. I don't know the dimentions of the bracket but can make one, but it would need to be 1/2" thick and that stuff's hard to cut unless you have a CNC to do it for you.
Ed
Old Jul 17, 2004 | 02:01 PM
I have can use the abrasive water jet at my school to cut them out all I would need is the dimentions, and the draw it in autocad and save it as a DFX file for the waterjet to be able to read it, the water jet is capable of cutting mild steel up to eight inches thick.
Old Jul 17, 2004 | 02:50 PM
Parrydise7's Avatar
I don't like being the one to rain on your parade, but this very subject has come up before. I don't recall if anyone ever came up with the dimensions (I don't recall that anybody ever did) but try a search. IIRC the idea of making your own brackets never got off the ground because they are available from other sources. Good luck.
Old Jul 17, 2004 | 03:04 PM
I was just wondering if anyone had the dimensions, not a big deal, I have the caliper carriers( much to hard to fab myself) purchased from sphon and I have spindles and disks. The only brackets I dont have are plates that go between the capiler carrier and the spindle, I will mock up the set up myself and figure out the dimensions thank you to all that replied, I was just trying to save a little work on my part.
Old Jul 17, 2004 | 05:56 PM
ebmiller88's Avatar
I totally understand. If I had a set of the brackets off the car I'd send you one to play with but I don't. Please post what you find out..
Ed
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
