Some questions on LCA reloc brackets..
Old Jul 16, 2004 | 09:35 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
#1, do they make bolt-on ones that I can then have welded? I want to be able to bolt them on and optionally have them welded (more than likely would. It'd just be easier if I could bolt them on at first, and I may be upgrading to a 4th gen rear)
#2, Will they fit the same on a 4th gen rear as on a 3rd gen?
The plan right now is to use the stock LCAs until next paycheck. I think this paycheck is gonna go towards chip-burning stuff and maybe the brackets if they make bolt-on ones. Otherwise I'm gonna start saving up for a 4th gen rear.
Old Jul 16, 2004 | 09:56 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
BMR makes bolt on ones. I don't see why you couldn't weld them later. Spohn's bolt on then get welded. I'm not sure if either will work on a 4th gen. But I don't see why they wouldn't.
Old Jul 16, 2004 | 10:02 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can swap BMRs bolt on ones between 3rdgens and 4thgens... ive done it before.
Old Jul 16, 2004 | 10:13 AM
Car: 1997 Corvette
Cool, good to know. Thanks a lot Should I notice quite a bit of a difference? As it is now, I can't put much more power to the ground than 1300-1500RPM or so from a dead stop. I mean I'll be using the stock LCAs for a while, so I know it won't be as good as it could be, but these brackets should at least show me a noticeable improvement, no?
Old Jul 16, 2004 | 10:18 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There will be an improvement but you will see your biggest gains with the LCA's. Using both together should make some of your traction problems go away.
Old Jul 16, 2004 | 10:20 AM
Car: 1997 Corvette
Cool. I'll go look into prices and maybe put my chip-burning stuff off for two more weeks then again, I would like to at least have an idea of how to burn chips by the time my LT1 intake/cam arrives..
Old Jul 16, 2004 | 10:25 AM
Car: 1997 Corvette
On Spohn's site, they show them as having a bunch of bolts in the picture but in the description say...
"Must be welded into place. Hardware is included. Since the brackets must be welded in place, we ship them bare. Weld in LCA Relocation Brackets are the only SAFE and EFFECTIVE way to install them."
Where can I find BMR products?
Old Jul 16, 2004 | 10:35 AM
Engine: 5.7, 5.0
http://www.bmrfabrication.com/
I would weld them.
Old Jul 16, 2004 | 10:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i know guys running consistant 1.6 60's with occasional 1.5s on good days... still have the stock LCAs.. they dont really hold ya back, sure, they flex in every direction... except the one that counts.
Old Jul 16, 2004 | 11:09 AM
Car: 1997 Corvette
I think I'll stick to Spohn because of the name, and they're cheaper than BMR I might just get the brackets and bolt them in for now. Like you said, they shouldn't flex much in the direction to cause wheelspin too much, so they shouldn't be *too* bad. I'll try the brackets first (they are cheaper too! lol)..
Old Jul 16, 2004 | 11:15 AM
Engine: 5.7, 5.0
I don't think you can just bolt the Spohn brackets on. I think you have to weld those brackets in.
Old Jul 16, 2004 | 11:22 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
spohns HAVE to be welded on.
they're just a "cup" that goes over the existing mount... the bolt locates it, but it has to be welded so it doesnt piviot.
the BMRs only bolt on because they also connect to the shock mount.. the shock mount keeps it from rotating.
Old Jul 16, 2004 | 01:41 PM
Car: 1997 Corvette
Bah, the bolt-ins are as expensive as new LCAs. Maybe I'll just save up for a 4th gen rear first.
Old Jul 16, 2004 | 10:59 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am just wondering what improvement people got with the lcarbs??
A tenth?
LB9GTA
Old Jul 17, 2004 | 01:13 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
My idea exactly, but I want a T56 installed before that and get some monster gears.
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
