wheel stud swap
Old Jul 21, 2004 | 09:14 AM
akamoose's Avatar
Car: 92 RS
Engine: 3.1V6
wheel stud swap
I want to swap out my front wheel studs to ones that are 1/2" longer. I know the thread size but I don't know the other specs on what the standard studs are, I don't want to take my car apart until I have parts to put it back together. So if anyone can tell me the measurements of the standard stud, and who sells longer ones I'd appreciate it.
Old Jul 21, 2004 | 09:22 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
arp makes ones that are 2.5" iirc. i know dorman makes them, but i dont know the length
Old Jul 21, 2004 | 09:51 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Here's a source:
http://www.thunderracing.com/catalog...vid=6&pcid=148
Old Jul 21, 2004 | 02:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The Dorman ones I get from Napa are the ones you want. You'll have to redrill the hole sout to install the ARP studs since they have a larger knurl diameter.
Ed
Old Jul 21, 2004 | 08:43 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Ed
Ed, Mine pulled right in, no drilling required. They were the .509" Knurl. I just used spare lugnuts to pull them into the rotors with my air rachet, Then used new lugs when mounting the wheels.
Old Jul 21, 2004 | 09:26 PM
ebmiller88's Avatar
Wow...Ok Dean...I cracked 2 hubs by not drilling the holes out a bit larger to .484"
Ed
Old Jul 21, 2004 | 11:51 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Ed
Were the ones you tried 1LE rotors or standard 10.5" rotors? Mine were the little 10.5's that I installed the ARP studs on. Wondering if the 1LE's have more face meat, or maybe even stronger quality metal.
I also pulled them into the rear axle flanges quite easily without drilling. No problems on the rear either.
Old Jul 22, 2004 | 08:06 AM
ebmiller88's Avatar
Standard rotors. The 1LE rotors have a LOT more metal so it's not as much of a concern.
Ed
Old Jul 22, 2004 | 08:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I also drilled mine out when I installed. I have the .509 Knoll studs (ARP - 7708). Although I didn't even try without drilling. (on standard 10.5", that were already cut down for the brake swap.)
Old Jul 22, 2004 | 09:23 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
only thing I can assume is that the front rotors I installed the ARP studs into were from Powerslot. After owning these rotors for awhile and realizing their poor metal quality (warping very very easily), one can only conclude that the metal is much softer on these than the stock GM rotors. Has to be why I didn't have a problem but everyone else has so far. I have also stated in other posts to NOT buy Powerslot rotors- I know I will never again.
1984HO
Mar 19, 2021 11:59 AM
IroczFan
Oct 6, 2015 10:13 AM
transaero
Aug 31, 2015 01:14 AM
LT1Formula
Aug 20, 2015 09:36 PM
