Abs Light
Old Jul 23, 2004 | 11:34 PM
TheBandit77's Avatar
Car: 1992 Camaro RS
Transmission: TH700R
Abs Light
I just changed my front brakes and now i notice my ABS light is always on. Somone told me you might have bumped the ABS. Well I don't even know where is the ABS. I own a 92 caprice with 305 EFI. Where is my ABS and how do i fix this problem.
Kyle
Old Jul 24, 2004 | 12:06 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
theres an exciter ring on the inside of the rotor or hub. did you change calipers too?
Old Jul 24, 2004 | 09:30 AM
Car: 1992 Camaro RS
Yes i did change my rotors. But where is this exciter ring? I also put in new wheel bearings.
Kyle
Car: 1992 Camaro RS
Kyle
Old Jul 24, 2004 | 02:37 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Do you still have your old rotor? Its a 92 caprice?
The exciter ring looks like a 6" dia wheel with multiple teeth notched into the outer radius.
If you look at the inside face of the rotor you will see it. You cant miss it.
Its conceivable that you got a rotor without the exciter ring. I say that because I know that 90-92 S10 rotors are IDENTICAL to 82-92 f-body rotors EXCEPT for the pressed on exciter ring. May have been just a parts mixup.
Guess you'll have to pull it apart one more time just to be sure before you spend $$ on diagnostics.
DO you have an ABS repair book? They can be finicky and some have special bleeding procedures.
Old Jul 24, 2004 | 04:58 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Sometimes your supposed to remove the old ring and install them on the new rotor. There is also a gap that you are supposed to set between the exciter ring and the wheel speed sensor. You need to use non magnetic feeler gauges to set it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
