9bolt to 10bolt ebrake?????
Old Jul 26, 2004 | 04:10 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
I can't find an axle shaft for my BW 9bolt, so I'm switching to a 10 bolt, with posi and disc brakes. My problem, diffrent e brake set ups. This is in an 89 firebird formula WS6. How or were do start on changing the ebrakes? Any help would be great,.
Old Jul 26, 2004 | 06:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just get the part of the parking brake cables that attaches to the rear end. It will hook right up to the part that's part of the car.
At least I think that's what you're talking about; these cars have a parking brake, not an emergency brake, whatever that would consist of.
Old Jul 26, 2004 | 07:35 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
moser engineering sells axles for a 9 bolt.
Old Jul 27, 2004 | 04:03 AM
doc76239's Avatar
Engine: TPI 305
Yeah they do at 150 for one axle and 250 for a set plus shipping and handling, plus bearings.
Old Jul 27, 2004 | 01:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sorry for not getting back to you on the axle, Doc...I just can't part with it yet. Another month, maybe.
RB's right, all you need are the correct e-brake cables. THey are no longer available from GM but they are from NAPA, P/N 94264.
HTH....Ed
Old Jul 29, 2004 | 01:37 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
I can get you a axel for a 9 bolt. My buddy has one out of a 89 Iroc that he swapped out. He bought a complete rear with 345's and swapped out his that had 277's. Which side do you need? How much are you willing to spend so I know what to offer him for his old rear?
Old Aug 1, 2004 | 04:57 PM
Parrydise7's Avatar
Are you going with Delco-Moraine iron calipers on the 10-bolt?
Old Aug 2, 2004 | 05:16 AM
doc76239's Avatar
Engine: TPI 305
weeeeeeeeee
I'm having fun with this dam rear end swap. The rear end I got was out of an 84 iroc. It was supposed to be out of an 91 iroc. The parking brakes on the 10 bolt are way to long to bolt up to the 9bolt setup. So i'm going to the junk yard on monday to take a look at a drom brake set up. Hopefully I can swap the parking brake brackets. And then the arm next to the drive line will not bolt up to the axle. I have an 89 firebird formula. Is there a differance between an 84 iroc arm and an 89 firebird. I thought they were all the same. Any help with this would be great.
Old Aug 2, 2004 | 08:18 AM
ebmiller88's Avatar
Ummm...unless I'm way wrong, there wasn't an Iroc in '84 and definitely not one in '91. I say this in hopes that you're not getting screwed around by someone....
Ed
Linson
Nov 12, 2015 08:09 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
N8MAN1068
Nov 14, 2001 10:30 PM
sb406camaro86
Jul 17, 2001 08:29 PM
True Power
Dec 8, 2000 08:17 PM
