disc to drum?
Old Jul 27, 2004 | 11:41 AM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
disc to drum?
I currently have a non posi setup and found a posi rear end with 3.73 with the non PBR brakes. I have drum brakes right now, is there anyway i can just take the disc brakes off the new rear and put the drums on and not have to do any prop chanes or ebrake line changes?
Old Jul 27, 2004 | 12:53 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Why not use the entire rear end? It'll give you posi, it'll give you 3.73 gears, and it'll give you disc brakes..
Old Jul 27, 2004 | 02:14 PM
meeklay812's Avatar
Car: '89 RS
I'm just weighing my options because my drum brakes are really new and i dont want to get rid of em yet. What would i have to do to put the drums on the new rear end? Would i have to change any prop valve or ebrake lines or anything??
Old Jul 27, 2004 | 09:26 PM
matt formula's Avatar
Car: 1990 firebird formula
Engine: V8 305 TBI
Transmission: TH700R4
dude what are you thinking! swap out your old rear and put the new rear in and use the disc brakes on the new rear. I just swaped out my old non-posi, drum brake rear for a posi, disc rear and rear disc brakes are soooo much better than rear drum brakes, trust me, you'll want the disc brakes, plus any money you would spend to swap your drums onto the new rear could be put toward the new componets for the disc brakes
Old Jul 27, 2004 | 10:58 PM
meeklay812's Avatar
Car: '89 RS
alright ill stay with the discs....What all do i need to put the new rear end on as far as brakes go?? New e-brake lines, prop valve?? How hard was it for you matt?
Old Jul 28, 2004 | 01:20 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
iirc, 98-02 rear brakes are a bolt on for disc brake cars if you dislike the non pbr disc that much...
Old Jul 28, 2004 | 01:23 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im partial to rear drums myself. Better E-braking .
Old Jul 28, 2004 | 09:59 AM
Engine: V8 305 TBI
when I swaped my new rear with discs I replaced everything, got new calipers, rotors, pads, and brake lines
Old Jul 29, 2004 | 02:12 AM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
I swaped to a 9 bolt 3.45, with disc and never changed the prop valve. And it works great, just my brake hose in the rear right is bad, changing tommarrow.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
