Possible problem with brake hub for brake upgrade
Old Jul 28, 2004 | 08:13 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am gathering all the parts for my LS1 brake upgrade, after taking a closer look at my hub I got machined about a year ago I noticed that the wheel stud knurl diameter is larger then stock. I guess the rotors that I turned down used different size knurl diameter then stock. My main concern with the bigger hole is the strength of the hub.
Here are the measurements:
Stock Knurl Diameter: about .500 inches or 12.7mm
My Hub’s Knurl Diameter: .575 inches or 14.6 mm
Distance from stud whole to edge of hub: .3 inches or 7.62mm
Below is a picture of the stud that came with my rotors (left), the stock stud (right), and the hole size. Do you think there is too little material around the stud hole.
Attached Thumbnails Possible problem with brake hub for brake upgrade-stud-size.jpg
Old Jul 28, 2004 | 08:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would be tempted to redrill the hub for the stock size knurls. I agree that the ones that came with that hub may not leave enough material. This is even more so being that the hubs are cast.
I've been wondering if the stock 'vette hubs (such as C4's are forged or not).
RBob.
Old Jul 28, 2004 | 08:29 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I personally don't see a problem with the thinness. Reason being that the studs you are using have a larger head on the backside than the .500 knurk stud do. That head flange areawill prevent the studs from pulling through in the unlikely event that the hub cracks for the stud holes to the outer edges. I would use them, however, I would inspect them after a short inteval of use (5k miles.)
Old Jul 29, 2004 | 05:03 AM
Mike454SS's Avatar
Car: 96 Caprice, 86 IROC
Engine: One has an LT1, one has an empty bay
I am confused. I thought that your hubs were just stock rotors that you had turned down. In that case, why did they touch the holes for your wheelstuds? Wouldn't you just want to use stock wheelstuds (or longer but otherwise the same replacements).
Old Jul 29, 2004 | 05:36 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That looks like a noticable difference in the knurls but I haven't noticed that much of a difference in the studs I replace the stock ones with (Dormans). I only have to drill the hubs to install ARP studs and I don't think there should be that much of a difference in them.
Ed
(I hope that made sense...it's early...)
Old Jul 29, 2004 | 08:24 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
The rotors I turned down were stock rotors that I got from someone on this site. I assume that they came off a car that had it's rotors replaced with some brand that happened not to use the stock knurl diameter studs.
Ed, have you ever seen larger knurl studs on any of the rotors you turn down?
Old Jul 29, 2004 | 08:39 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i didnt drill at all for my arps. no cracks going in, and none as of 30 miles
Old Jul 29, 2004 | 09:59 AM
ebmiller88's Avatar
No, they have all been the same, either GM or aftermarket rotors. Also, that knurl diameter seems a bit big. I have to drill a .484" hole for the ARP studs I install so the .575" you listed seems wayyyy big.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
