cgs subframe connector install
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i plan on installing my subframe connectors tomorrow. the instructions say to jack the car up by the suspension but i plan on using cinder blocks under all four tires. and my question is when i unbolt my lca will the axle want to move at all or will it just stay in place. also any other tipswill help greatly. and one last question my kit only came with four of the shorter little stubby bolts werent there supposed to be six?
Engine: LO3 and LT1
so far i have the whole driver side connector in all the holes drilled and bolts in but i can not seem to find out how to get the nut on the bolt for the front flange that bolts to the subframe. the rear bolt on the flange has a hole stamped from the factory that you can access easily. but there is nothing like this for the front one. any suggestions?
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
