EBC Brakes
Old May 25, 2002 | 11:34 PM
Jack D's Avatar
EBC Brakes
Anyone have any experience with them. They make rotors and pads. There pads are supposed to be dustless and great stopping. They are called green stuff. GP over on ls1.com. Wonder if anyone had experince with them.
Old May 27, 2002 | 05:28 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I just got a set for my 1LE upgrade but I haven't installed them yet. I used them exclusively on my ZX6 Ninja and they are (were) a great pad. They have been making pads for years and like I said are very popular on motorcycles. I don't think you'd be going wrong by buying them.
Ed
Oh yeah....greenstuff for street, red stuff for race.
Old May 27, 2002 | 12:29 PM
Jack D's Avatar
Old Mar 14, 2003 | 08:25 PM
LeD FrOg's Avatar
I just installed EBC rotors for the first time and EBC pads for the 2nd time today. I used the GreenStuff pads for awhile with some cheap rotors and they got warped, so this time I speant the money and go the good stuff. So far they seem perfect. I swear by EBC. They have a little whining noise right now, but EBC says that goes away after about 200 miles bed-in time. All in all I speant $280 on the pads and rotors from TireRack.com. I also replaced the calipers with re-manufactured ones for $12.99 each.
Old Mar 31, 2003 | 09:03 AM
chrissy's Avatar
ebc
green stuff pads are the way to go if you just want every day road use. But if ur cars track only then i recomend black stuff, if u take the to the car to the track and highway then red stuff.
Old Mar 31, 2003 | 11:04 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
O.K. I Have tried EBC greenstuff pads and am not impressed at all.
I only went this route because of there popular use around these board- and figured I'd give them a try. They have been on there for about a month now and I am ready to scrap them and go back to my Stillen pads.
When I put them in and conditioned them, right off the bat I noticed a difference between their feel and the Stillen pads' feel that I know well even unbedded.
EBC pads after broken in have too much initial bite ( not smooth and predictalbe/controllable)
They produce fade in conditions where Stillen pads never do. Stillen pads get even better with heat, however, they are warmed up by the time you reach the end of your street corner(Not a full race pad- great for street use)Normal rotor friction without apply brakes will warm them in about 1 min or so.
EBC pads lock too easily- Stillen pads have a much better sweet spot- meaning you can come down harder on them without locking as soon
Release feels about the same on both pads.
Stillen are less expensive for my application also ($62 vs. $79 for EBC)
I would recommend you guys try them and stay away from the EBC marketing bandwagon. EBC are not bad but Stillen is a better pad hands down- I promise you- I have run these pads on all of my vehicles for years now and regrete trying the EBC's
P.S. I run Stillen rotors on all my cars also.
http://www.stillen.com/brakepros.asp?subcat=263
Old Apr 22, 2003 | 09:24 AM
chrissy's Avatar
I have just recently herd of a new pad called blue stuff which lies in between redstuff and black stuff it also has a wider operating tempeturewhich is 50degrees and 800degrees.
chrissy.
Old Apr 22, 2003 | 04:07 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I have a set of EBC's waiting to go on my car so I can't comment on stopping performance. That will be determined once my 1LE upgrade is on the car.
However, I can comment on the craftsmanship of the EBC pads. IMHO, they aren't put togther as good as they could (should) be. For $80 I expected better build quality. One screech clip was loose and all the green paint on the backing plates created a poor fit in my 1LE caliper carriers.
To remedy the problem I broke out the Dremel and smoothed and polished ALL the contact surfaces of the pad backing plates that interact with the carriers. This made for a big improvement, but again, at $80 I shouldn't have to "massage" the pads to make them fit better.
When the time comes I'll be going back to Hawk or may try the Stillen pads AGood2.8 recommended.
Old Apr 23, 2003 | 07:38 AM
ebmiller88's Avatar
I agree...I had to "massage" my pads to fit in there also. I'll be going with ceramic pads next time...too much dust with the EBCs.
Ed
Old Apr 23, 2003 | 03:50 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Its been about 1 month now with EBC greenstuff pads and my opinion of them is even worse- I highly recommend Stillen pads. The EBC's also have much more dust than stillen pads.When i start to depress the pedal, for a slight moment there is nothing then all of a sudden whammm, very non-smooth non-predictable initial bite. Stillen pads are smooth and have that always there feel to them - very predictable and you can come down on them much harder than EBC's without locking.
Old Apr 24, 2003 | 05:01 PM
laiky's Avatar
I haven't tried the greenstuff in my car but i know in the MC world they are not the best. Strangly EBC makes a sintered mettalic MC pad that is incredible. It turms a four finger (motorcycle) stop into a single finger stop. I run them on my suzuki and i love them! The Greenstuff pads faired well for rotor wear but i remember in many tests they were not as good as others. I was thinking about trying the Greenstuff on my car but now i think i will look elsewhere.
Old Jul 31, 2004 | 02:28 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
bringing it back form the dead....does anyone else have anything to say on this matter? i need some good stopping power (at least better) but all ive ever heard is ebc, ebc, ebc. would the stillens be better for my street application? also what rotors does one recommend?
Old Jul 31, 2004 | 02:37 PM
ebmiller88's Avatar
Maybe Hawk's pads??? I dunno...I'm using stock PBR pads in my RS w/ C4 HDs (Iroc w/ EBCs is parked for a while...) and they are pretty good, not much dusting at all.
Ed
Old Jul 31, 2004 | 04:16 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I really like my Hawk pads. I use their HP+ for autocross, they're noise, dust alot, and stop great. I've heard others say that their HPS pads are quieter, cleaner, and still stop pretty good (compared to the +).
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
