02 SS rear swap, what rear offset now?
Old Aug 2, 2004 | 05:09 PM
spodeboy's Avatar
Car: 1986 IROC
Engine: 400 SBC bored .060
Transmission: Tremec TKO
I just put in a 02 10 bolt, and I want to run 11" ZR-1s. What offset do I need for my 86 IROC? Anyone got some pics for spacing purposes? Do I have to roll the inner fender really?
Old Aug 2, 2004 | 08:46 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I'm pretty sure the stock rear offsets on a 4th gen would be perfect for the rear tires. You deffinetely need adaptors in the front, not sure what kind/measuremeants.
Old Aug 3, 2004 | 05:15 PM
spodeboy's Avatar
Car: 1986 IROC
Is the right offset 50mm? Do the tires stick out?
Old Aug 3, 2004 | 05:33 PM
FLYNLOW92rs's Avatar
stock offset and no the tires don't stick out
I have a 4th Gen SS rear on my car.....
Pictures in sig.....
Old Aug 3, 2004 | 10:09 PM
spodeboy's Avatar
Car: 1986 IROC
what is the stock offset?
Old Aug 4, 2004 | 04:12 PM
spodeboy's Avatar
Car: 1986 IROC
Does anyone know? I have seen some of us have 17-11 rears in ZR-1s. What is everyone using 3rd gen rears and spacers? 4th gen rears and 36mm offset? 50mm offset? Do you have to roll the inner lip?
Old Aug 5, 2004 | 12:44 PM
Ucantcme57's Avatar
The 4th Gen wheels are:
16x8 55mm offset (6-5/8" backspace)
17x9 55mm offset (7-1/8" backspace) WS6/SS
That is what I was told...
What is the 3rd gen rear wheel specs?
I guess I have two more inches of backspacing to eat up just trying to figure out what to tell american racing for my tt II's..
I was going to use 4th gen front tire specs and 4th gen rear tire specs the difference in stock backspacing of 4th and 3rd then divide up 3 inches each...
Trying to go 335/35/17 Michelin's
Old Aug 5, 2004 | 12:48 PM
Ucantcme57's Avatar
How wide did you go flynlow?
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
draco
Oct 4, 2015 09:25 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
E Rod
Aug 28, 2015 05:17 AM
