what rears fit out 3rd gen
Old Aug 16, 2004 | 05:36 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i have an 85 z28 with drum peg leg and i want a posi disk rear for it, is there any other cars that i can look for one in other than 3rd gens. i don;t want 4th gen due to rim spacing issues.
thanks
Jeff
Old Aug 16, 2004 | 07:58 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
No, unless you want to modify a rear from another car, but since you want to keep wheel spacing, I'm guessing you don't want to hack and weld.
Old Aug 16, 2004 | 08:07 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Then you are out of luck, unless you have a extra $2500 to spend.
Old Aug 16, 2004 | 08:38 PM
JeffW's Avatar
Engine: 305 tpi LB9
so it is just third gens...... i must find then. thanks
Old Aug 16, 2004 | 11:08 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Actually the rearend out of a Blazer S10 should work. bbtaz97 has a '93 and the rear is the same. As for spacing, I'm not positive, they may be the same. My 4th gen LS1 rear fit on my car perfectly, though kicked my tires out a little bit on each side. Doesn't look too bad though..
Old Aug 17, 2004 | 12:44 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I'd hate to say it, but out of coincidence my step brother has the exact same truck your talking about and there is no way that it will just bolt on, especially with it's LEAF SPRING rear suspension. You can mod it, like 99.9 of all the other live rear axles in existance to fit, but not bolt on.
I do know a lot of the full size GM SUVs use the coil/multilink live rear axle, however I really doubt everything is in the same position
Old Aug 22, 2004 | 01:36 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Do you have any pics of yours and what had to be done to be able to use 3rd gen rims?
Old Aug 22, 2004 | 07:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A S-10 rear WILL NOT work; it has no provision for the torque arm. The innards out of it will work in our housings, but the truck housing WILL NOT bolt into one of these cars, without a bunch of fabricating on something.
There's no way to use 3rd gen wheels on a 4th gen rear in one of these cars and have the wheels not get that silly rĄcer "skateboard" effect, unless you know of some way to make spacers with negative thickness; that is, spacers that take space out, instead of adding some.
Old Aug 22, 2004 | 10:23 PM
Engine: Your Momma
Make a spacer out of DARK MATTER, you know, that stuff that's supposed to be inside black holes. Just a tiny bit and the problem is solved!:lala:
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
I'llrocya
Feb 2, 2016 11:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
reiderz iroc
Aug 13, 2015 04:57 PM
