Brake warning light ?
Old Aug 19, 2004 | 02:05 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yo guys. Those of you who have installed the Wildwood or Summit adjustable proportioning valves: What did you do with the sensor that goes into the stock prop valve that goes to the brake warning light?
Also, what is that little round plastic cover on the front of the stock valve?
Thanks.
Old Aug 20, 2004 | 01:19 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
either the plug for the warnign light, or is where the pin is at to depress when are bleeding the brake system out
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
