I got new tires had a really bad experance. what should i do?
Old Aug 21, 2004 | 07:18 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
well i had to get new tires today. its about 10:00 am i go to drop my car off at the gas station to get my tires put on they told me it would be an hour and i return in an hour there not done i think o well its cool i leave and come back 45min later still working on it not a big deal i stay 15-20 min later i am readdy to go the guy backs out he get out and says somethings rubbing to the other worker i go back in side i hear this horiable grinding sound he jacks it up and looks he puts it down and askes me if i have heard my breaks rubbing i say no just squicking when i stop a little i go to back out and i hear this horiable grinding again i say to him its never done that he pulls it back in he said he put the tires on rong he put the back wheels on the front and the front tires on the back they where screapping the calipper so i leave and i am rally mad now i leave and come back 1hr later i see that my wheels are covered in oil hand prints and there on oily finger prints on my arm rest as i drive away i fell that my wheels are wobbling back and fourth now the car pulls to the right
heres a list
1. my wheels screapping the calipper
2. wheels are wobbling back and fourth
3. oily finger prints on my arm rest
4. wheels are covered in oil hand prints
ps and the week before i got my oil changed and the spilled some on my engine and now the oli has to bern off and my shifter has covered in OIL!!
Old Aug 21, 2004 | 07:31 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Id talk to the manager, show him all the defects within the
job , and demand a compensation for the damage.
And I wouldnt go alone, bringging ppl with you makes for
a better deffence I find.
If you go alone, the mechanics and/or shop owner can try
to contradict you, claim not responsible..
The more attention the situation gets , the quicker they might want to solve it.
And i wouldnt pay, and leave the car there, as if you leave, they
could blame the damage on a later action.
anyhow, good luck to you 91rs, hope you get your way.
Old Aug 21, 2004 | 09:30 PM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
Everything Spectre said, and don't ever go back to those hacks again for ANYTHING
Old Aug 23, 2004 | 12:57 AM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
I swear...sometimes I think monkeys would work better on my car rather than some of these goons at the shops.
Good luck to you my friend.
Tommy
Old Aug 23, 2004 | 11:12 AM
Car: 1997 S10
well i went back to day i hope wverything is fixed now thanks for the help
Old Aug 23, 2004 | 11:52 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
damn people nowadays, this is why i never get a shop to do anything. they either screw it up or charge you an arm and a leg
Old Aug 23, 2004 | 03:24 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The shop I go to at first almost switched one front and one back, but they realized it before they even bolted them on. lol, also the one guy didn't realize the tires were directional at first. Actually, I think that's how it got screwed up in the first place, he forgot which rim was going on what corner, etc. They realized it and corrected it immediately though, like I said they didn't even bolt them up. You would think that most shops would fix an error like that as my shop did (if they even make the error in the first place).
Old Aug 31, 2004 | 10:42 AM
Car: 1997 S10
well i still am having trouble! i have been back there like 4 times. i went back and they said i had a bad front tie rod so i had that fixed. then i drove it home then it stilled pulled to the right. then i called him and said it still pulls to the right so he said i will have to have it for 4 hrs i said ok i will drop it off . ok first i had to have my wheele turned to the left so the top of the wheel was diagonal to make the car go straight. so i get back there to get my car and some desk worker gives me my keys and says he did not find anything i drive it home and the wheel is level now but IT STILL PULLS TO THE RIGHT!! and now theres play in the wheel when i turn right and its tighter when i turn to the left. could the dumb person who put my wheels on rong have schued something up?
Old Aug 31, 2004 | 10:45 AM
colonboy14's Avatar
Car: Trans Am
Go to a real shop, not a gas station.
Old Aug 31, 2004 | 10:53 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
If you really believe its their incompetence that is causing the problem, AND it keeps getting worst every time they touch it (Sounds this way to all of us here)
I highly recommend you take your reciepts showing the work performed to ANOTHER "REPUTABLE" shop and pay them to fix the problems while DOCUMENTING what errors where done by the previous shop- again, show them your reciepts first before any fixes are peformed.
Then go back to the original shop with copies of those repair reciepts and demand your money back for the shabby work performed AND what damage they caused (The other shop can disclose this info for you also and let you know what the first shop is liable for). They will pony up or will lose in small claims court.
Old Aug 31, 2004 | 10:54 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I would go to a real shop, have it fixed correctly, then take the first idiots to small claims court and get ALL of your money back from them plus the money to fix what they screwed up. It's a hassle, but it's obvious that they are in over their heads and will continue to screw things up even worse if you keep taking it back. They have no clue what the problem is.
Troy
So Cal
Old Sep 3, 2004 | 11:44 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
the best advice i've seen in this thread.
Old Sep 3, 2004 | 12:11 PM
Car: 1997 S10
thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
May 20, 2016 07:01 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
B_Dubya
Aug 26, 2015 05:09 PM
