What has happened here?
Old Aug 26, 2004 | 01:42 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
What's up? Well, me and my dad put a lot of new stuff on the front end of my '89 RS including new struts, springs, polyeurathane bushings, steering brace, polyeurathane endlink bushings, and new bushings for the sway bar. The car handles better than it did before, but that's all I can really say. After completing everything it was time to put it back on the ground. When we did the whole front end of the car looked like it had a lift kit on it. I swear, I can put one whole fist and half of the other one between the tire and the fenderwell. It really doesn't seem as stable as I thought it would be. Does anyone know what's going on here?
Old Aug 26, 2004 | 01:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
try to re-index the front springs.
Old Aug 26, 2004 | 01:46 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
new springs? were they stock replacement springs? read my post here:
https://www.thirdgen.org/techbb2/sho...hreadid=255593
Old Aug 26, 2004 | 02:27 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Loosen the bolts on the control arms that mount to the cross member, the bushings may have binded. With the car on the gound, loaded; no jacks/stands, i had to the "bounce" the front a little to resettle mine, then tighten the bolts again.
(forgot a word)
Old Aug 26, 2004 | 03:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Index springs...
Ed
Old Aug 27, 2004 | 12:17 PM
Car: 1989 Camaro RS
what does it mean to index the springs? Sorry, I'm only 17 yrs old, but I'm trying to learn everything I can. Please have mercy for any stupid questions.
Old Aug 27, 2004 | 12:50 PM
Steve89GTA's Avatar
The springs NEED to sit a certain way when you put them in. The bottom end of the spring (make sure you have them in the right way) needs to sit inward in between the two drain holes..you will see them there. Make sure the top isolator is fastened nicely to the spring or it will move off when you install it (I used lots of tape).
Lastly, make sure to tighten everything at ride height.
Old Aug 27, 2004 | 01:08 PM
ebmiller88's Avatar
Click the link in my sig for a picture how-to of indexing springs.
Ed
Old Oct 8, 2004 | 04:41 PM
Car: 1989 Camaro RS
Hey Forshock85TA, is it safe to loosen the control arm bolts with all the weight on them? I really don't want to get hurt.
Old Oct 8, 2004 | 09:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
First support the front of your car car w/jacks.Then just loosen the bolts a little.Dont remove them though.Dont forget to make sure your springs are indexed.If you havent done that already.Then you may have to disconnect your ball joint or even the A-arm bolts.To index them.
Old Oct 9, 2004 | 04:46 PM
Car: 1989 Camaro RS
Alright, will do. I will post a reply after I have tried. Thanks.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
