Along the edge of the sail panel, where it meets with the top of the car...there is a small crack....and I don't want it to get any worse. Do I need sub frame connectors even though I don't race???
everyone can benefit from subframe connectors. i went with jegs, they were built solidly and run along the pinch welds kinda like spohns, although these seemed beefier along with about 34 pounds added to the car. I haven't seen spohns in a while so don't knock me, just going off memory.
Spectre
close
- Join DateSep 2001
- LocationMontreal\Quebec|Canada
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- CarCamaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
- Engine3.0L/183
- Transmission4 spd auto/OD
- Liked:0 Times in 0 Posts
SFC streghten the unibody .. its a wothwill mod.
Id go for it.
Id go for it.
The day you install subrame conectors youll ask yourself why you waited so long to do it.
I got the BMR subrames. & I noticed on every speed bump, every hole, every corner, a lot of things in your car will stop making noices. basicaly if you do a good job and well them you will love them. I think that SFC is the only mod Ive done to my car (& Ive done a lot) that Ive said WOW! what a difrence!
I would definetely get them. I can't think of any reason not to get subframe connectors. Mine are actually being shipped to me right now.
The SFC's help anyone who owns a unibody car. It gets rid of a lot of shakes and rattles. Hell some SFCs you can buy for like 130 new...though those usually affect ride height.
Sounds like I'll be getting a set then. I really like the style of the Kenny Browns, so I'll probably go with those. The hardest part is going to be to try to find a good shop to install them right....and to do a good job. I have heard that the SFC's are well worth the money....but just wanted to see if they are worth it even though I don't race...and it sounds like they are!
