baer brake swap
Old Sep 7, 2004 | 06:04 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
baer brake swap
swapping rear disk to 12" baer brakes does the rear axle have to come out to install backing plates or anything like that?
Thanks Jeff
Old Sep 7, 2004 | 06:09 PM
Spdfrk1990's Avatar
Yes you have to pull the axles to install the backing plates.
Old Sep 7, 2004 | 06:10 PM
JeffW's Avatar
Engine: 305 tpi LB9
do you know how on a bw 9 bolt?
Old Sep 7, 2004 | 06:13 PM
Spdfrk1990's Avatar
They pull out after you unbolt the backing plates.
Old Sep 7, 2004 | 06:23 PM
JeffW's Avatar
Engine: 305 tpi LB9
something needs to be removed inside the punkin most have a c clip i can;t find it in this rear.
Old Sep 7, 2004 | 06:24 PM
Spdfrk1990's Avatar
Trust me on a 9 bolt thats how you do it i have 1.You just might have to pull kinda hard. A 10 bolt would have c clips.
Old Sep 7, 2004 | 06:27 PM
JeffW's Avatar
Engine: 305 tpi LB9
sweet thanks
jeff
Old Sep 7, 2004 | 06:29 PM
Spdfrk1990's Avatar
NP Im converting mine to PBr's it had the ****ty pre 89's also. Just been so busy dont have much time just have to get the earl's lines now and new front pads.
Old Sep 7, 2004 | 06:31 PM
JeffW's Avatar
Engine: 305 tpi LB9
that was so easy i'm embarased
i always thought there were clips that explains why i could not see em
Jeff
Old Sep 8, 2004 | 02:08 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Why don't you just get an LS1 rear? Besides the obvious tire sticking out issue it's easy to find one in good shape with posi and good gears for 1/2 the price of the kit.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
