4th gen rears traction control?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
For those that have done the 4th gen rear swap does it matter if the rear has traction control or not? I have found some with traction control and some without. Just wondering if it matters at all, and what the difference is.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres 2 ABS/traction control rears out there.
one (more commonly found on the LT1 rears) has a sensor ontop of the pumpkin. if the sensor is not in there, then you need to make a blockoff plate... its just a small (about 1" ) hole you need to cover, with a bolt hole next to it.
the other rear has the sensors on the axle near the flanges. you dont need to do anything to them.
There IS a difference. The 4 channel (traction control) rear has 2 separate brake lines, while the 3 channel (ABS) rear has a single line that splits in factory thirdgen fashion. Since you cannot reuse your stock brake lines, you will need the lines off a 3 channel rear or make your own.
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I was able to replace the 2 line setup on my LS1 rear end with stock lines from a 3rd gen with discs. You have to bend the lines a little bit to get them to reach the brakes, but they worked fine.
Car: 91 Camaro Vert
Originally posted by MrDude_1
use your 3rdgen brake lines.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just bought new lines and connected them to the stock "T" that attaches to the top of the pumpkin.
If you change the brake lines, it doesn't matter what rear you get.
Traction control rears have the sensors in the backing plates and reluctor rings on the axles, and the non-TC rears have the ABS sensor in the top of the pumkin.
If you need to change the studs for some reason, having axles with traction control makes it harder to replace since the reluctor ring needs to come off and it is pressed on.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
