Different Spindles on our F-bodies??
Hey guys. I'm new to the 3rd gen. cars.
I've got a question for the resident experts here.
Are there two different types of spindles? I had a guy say that he thought GM used two different spindles throughout the years on the 3rd gen.
Anyone know? Or have pictures of them??
Thanks!
Thanks!
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
The spindles were pretty much all the same throughout the years. It was discovered and brought up in the LS1 brake thread that there was a difference in some of the holes for dust sheild on the spindle. The earlier spindles had more of a raised area around them and later ones didnt.......or something like that. So there could be a difference in other small things too. But overall the are all about the same.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
There are standar brake spindles and 1LE brake spindles from the factory.
The 1LEs are made from the standar spindle castings. The were cut and drilled from the factory- You can do this yourself with basic tools. (Cutoff wheel grinder, drill and bit .332", and a 3/8-24 tap)
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
So that is all i would need to do to upgrade my regular brakes to 1LE brakes? Besides new rotors and pads and calipers
Car: '87 Cam RS V6
Engine: Top Secret
This is the same exact modification needed for Baer brakes also- matter of fact I think thats where I originally found this document. Baers are basically identical to 1LE's, just prettier looking- same PBR caliper.
Car: 1988 Formula
Engine: 355
Might refer to this post for info on brake modification. I am doing the LS1 swap also. Very long post but good info.........
https://www.thirdgen.org/techbb2/sho...s&pagenumber=1
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I used this thread to assist in modding the front brakes (check Spohn's site. He sells the 1LE kit):
http://www.ws6transam.org/1LEbrake.html#1LEfront
Here's another thread, should you ever decide to do the rears:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
JamesC
gm did have two different spindles. One is for the 10inch brakes and the other is for the 12 inch 1le brakes . You can put 1le brakes on your car but you have to cut some parts of the spindle off and you also have to drill and tap two dust shield holes.
heres some pics. I did c5 corvette brakes but the idea is the same .
88SS6SPEED
Nov 11, 2015 07:05 AM
rb85TA
26
Sep 14, 2015 10:29 PM
