Is it better to tie a roll cage into the subframe connectors or use the weld in plate
Old Nov 20, 2004 | 09:17 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Say you were going to use a set of Spohn sub frame connectors that weld in along the seam of the underbody, as well as a S&W race cars 8 point roll cage/bar.
Would it be better to weld the cage directly to the subframe connectors or use the supplied plates they give you to weld it to the body?
Old Nov 20, 2004 | 01:24 PM
ede's Avatar
ede
depends on how you define better. all you need to do is weld the tubes to the plates and the plates to the floor.
Old Nov 20, 2004 | 03:15 PM
Car: 1992 Camaro
Engine: 350 miniram
I actually was trying to find out if tying it to the subframe connectors would make it a good deal more rigid than with the weld in plates that attach to the body supplied with the kit?
If I would never know the difference between the two, then no way would I cut through the floor and make a lot of extra work for myself.
Old Nov 20, 2004 | 05:59 PM
ede's Avatar
ede
you'd never notice and if you would you need more than SFCs and a cage
Old Nov 21, 2004 | 02:50 AM
Car: 1992 Camaro
Engine: 350 miniram
Perfect, that was exactly what I needed to know.
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
