New Wheels, need tires
Car: 1991 RS
Engine: 305 TBI
I just got a new set of 18x9.5 Chrome C5 wheels. I need to get tires. I was thinking of getting 245-40-18's in all four corners. This would retain the same tire diameter as my current 245-50-16's. Does anyone have opinions on the 245-40s? Is this enough meat for a good ride and for good performance? and should I go with a bigger tire in the back than in the front? I want to get BFGoodrich KD's. Any opinions on these type of tries?
Car: 2002 Z28
with 9.5" rims you shouldnt run anything smaller than 275s unless you want the lip of the rim to hang out farther than the tire, which i think looks terrible. If i was running those size rims i would go 275 or 285/35/18
Car: 1991 RS
Engine: 305 TBI
But if i put 275-35s on those rims will the tires be too wide in the front? Will the front tires rub onsharp turns or would I be ok? I do not want to do any fender mods if at all possible.
Car: 2002 Z28
there are alot of people running 275/40/17s on 17x9.5 inch rims up front without problems. Id rather have alittle bit of rubbing than a tire that way too small for the rim
depends on what size adapter you choose to run but you should be running 275's.
use this...
http://www.miata.net/garage/tirecalc.html
245's on a 9.5
use this...
245's on a 9.5
LT1Formula
Nov 16, 2015 01:13 PM
