k-member bottom pix for oil pan clearance?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone have there car on the lift, and lay down and take a picture of the tubular (profab, etc) k-member? I need to see how far forward the bar is vs the stock k to see if my new oil pan will clear.
Not looking for measurements, just a picture if someones got one.
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Kandied91z
what type of pan? i have a canton 7 quart race pan and it fits with no troubles.
Its the same depth, pretty much same width. But its about 8 1/2" long on the sump part (front to back), and the slope is more gradual than the stock pan. Way more gradual. The stocker is clearanced for the y-pipe big time.
So I'll cut and remake the y-pipe to go forward a bit more, but I'm curious how much more "room" i have with the profab k-member.
-- Joe
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you'll still have plenty of room.
take the stock K member.
take the leading edge of it... now place a bar infront of the leading edge...
thats where the profab/PA racing kmembers are.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Is it then possible, with the profab k-member to unbolt and remove the oil pan with the motor inplace and undisturbed??
-- Joe
Car: 91 Camaro Vert
Originally posted by anesthes
Hrmm.. Sheet, really? Maybe I'll remake my y-pipe with 3" then.
-- Joe
-- Joe
i havent tried it.
but i did it with the stock kmember by just lifting the engine a few inches off the mounts.
i recall it would just BEARLY not clear unless i did that.
so, if i was to take a guess, yes you could. you could easily. ive never tried it, but my guess is you could.
if nothing else, atleast you can get at all the pan bolts easier....
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
i can with the pa.
i can with the pa.
I'll have mine bolted up sunday. Gotta assemble the motor this weekend..
Thanks guys!
-- Joe
the only real benefit i see to having a tubular unit on a street car is being able to work on it. night/day difference, well worth it for that alone as the room is just outstanding.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
looks pretty good, too bad it wasn't in more focus.
Originally posted by greezemonkey
Yea, my fault...I was pretty new at using the new digi cam and focus was a "mystery item" at the time..I will take some new ones this winter when the car is on the rack next...hated to post it like that but :shrug:
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
-- Joe
-- Joe
Kat
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Kat
I have a 3" y-pipe with the stock K-member. Fits great and clears everything. It only sticks about a 1/4 below the K member or so.
Kat
Kat
-- Joe
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
:shrug: I dont have aftermarket 3" y pipe. I made my own. That prolly has something to do with clearances being kinda "tight" but have enoug room where it clears everything.
Yes where the actual "Y" is now two 90° bends with a another 3" 90° coming off of that.
Kat
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
heres the front shot.. Even tho it looks like it is sticking down further than what it is..
Yes I can't weld worth a damn either. lol
Kat
Kat
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Kat
Kat
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
