Spring rates for 87 IROC??
Old Feb 6, 2005 | 06:54 AM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Does anybody know what the factory spring rates were for an 87 IROC? I would like to lower the car and get some stiffer springs for it, but before I go shopping, it would be nice to know what the current springs are. There used to be a guy in the nieghborhood that had a spring tester- he tested a set of springs I had from a 1LE- they were 485 lbs/in. I think I need stiffer. The car is used mostly for open track days at road courses. Thanks for any help. Pat
Old Feb 6, 2005 | 09:18 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
i know that the eibachs pro kit are 710 lbs front and like 130 lbs rear.i have suspention tech springs and they are a 1" drop with a 608lbs front sprngs and a 99-190 progressive rate in the rear car feels good.get and eibach kit or a hotchkis.
Old Feb 7, 2005 | 05:44 AM
hotrodln's Avatar
Engine: Lt1 in IROC
Hey thanks for the info. Does your car handle pretty well with these springs? I guess they lower the ride a bit over stock IROC springs? WHere"s a good place to buy the eibachs? Summit? Thanks Pat
Old Feb 7, 2005 | 06:08 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
anywhere like jegs, summit or any of the above sites like spohn.net
Old Feb 7, 2005 | 09:13 PM
hotrodln's Avatar
Engine: Lt1 in IROC
ok thanks !!
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
tmellott89
Aug 16, 2015 02:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
