Stock Iroc's?
Old Mar 2, 2005 | 10:26 PM
89blackm's Avatar
Stock Iroc's?
Whats the biggest rim u can fit on the 16x8 rims?Im looking for straight line only.Its not a road coarse car
Old Mar 3, 2005 | 09:47 AM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
I have no clue what you are asking. Whats the biggest rim you can fit on a 16*8. I think you mean tire and i beleave people are running 275/50 16. But not positive.
Old Mar 3, 2005 | 11:31 AM
89blackm's Avatar
haha yeah sorry i meant tire it was a long day.If someone knows for sure let me know please
Old Mar 4, 2005 | 12:07 AM
83 Crossfire TA's Avatar
295 50 16 will "fit"
Old Mar 13, 2005 | 10:57 AM
klumb15's Avatar
a 295 might fit on a 16x8, but not worth a sh*t...the tread is gonna stick out on each side, and I doubt you'll have any sidewall strength what so ever....i started a thread abotu this a while back and got a lot of responses...i believe a 255 is the most you can go on a stock rim while maintaining decent driveability....265's is pushin it......somebody has to know for sure....
Old Mar 13, 2005 | 11:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Well if you say this isn't a road course setup, sidewall strength isn't needed too much. mw66nova runs 275s on his 7" wide wheels... You shouldn't have any problems with at least that size on an 8" wide wheel.
Your main concern is, what tire shop is going to put the rubber on the rim for you? then, what will they put on it for you ? Some may be concerned about your safety etc, and might refuse to put super wide tires on.... That's probably where you want to be asking....
Old Mar 13, 2005 | 12:08 PM
klumb15's Avatar
yea i think the original question is wrong.....89blackm is a buddy of mine, and this car is not a car just to go a quarter mile at a time...its an everyday driver...i realize you can stick a huge tire on a skinny rim, but it won't allow you to have any decent handling...correct me if i'm wrong but a 265 is the biggest you can go while maintaining stability, i would never run more than a 255 on an 8" wide rim....
Old Mar 14, 2005 | 06:45 PM
Actually, 295/50/16’s specify a 8-10” rim… I wouldn’t call it optimum, but mounting them on a stock 8” rim works fine, and they should handle OK for a big, tall tire.
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
Leggman1
Aug 6, 2015 04:15 AM
