adj. LCA and Panhard bar
Old Mar 2, 2005 | 11:55 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i am looking (ok need to) purchase a set of LCA's and a panhard bar. i was thinking of going with spohn's version but which ones should i use. the car is just a summer ride and will see the drag track three times a year. no road racing or anything like that and i am not going to lower the car either. i am running the zr1 rims (17x11) but dont know what tire size yet (275 or 315). maybe next year i might replace the rear with a 9" also but not to sure yet cause i dont know if the rear can handle the stroker motor. any tips will be helpful.thanks
Old Mar 4, 2005 | 09:33 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
If you arn't going to lower the vehicle then you really don't need adjustable stuff. and fyi I have a set of Global west lcas for sale, they are non adjustable and have the bearings on boath ends. I am going to get some adjustable ones because I have sportlines.
Old Mar 17, 2005 | 07:46 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
How much do you want for your lca?
Old Mar 17, 2005 | 02:24 PM
camaro05's Avatar
Car: 91 Z28
I would like 200 shiped for the LCAs. they are 300 new and only have a coupple thousand miles on them. and for tires, if you go with 17X11 I would get at least a 295/35/17 but I have seen a vette with 315s and they look verry good. just don't get a 275, that is way to small.
Old Mar 30, 2005 | 04:11 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
dont do anything less than 315's or you will kick yourself in the ***.i had the zr1's with the 315's they look soooooo huge n sweeet people would stare lol...now i have the 18x10.5's zo6's with the 295's....omg what a difference the 295's look so crappy n small to me....pic 1
Old Mar 30, 2005 | 04:12 PM
irocdan's Avatar
Car: 88 Iroc vert
pic 2
Old Mar 30, 2005 | 05:07 PM
smokefan's Avatar
irocdan did you have to do any fender rolling with the 315's. how bout the front running 275's. any rolling there
Old Mar 30, 2005 | 06:44 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
did you have 315's in the front too? That must have requred some work.
Old Mar 31, 2005 | 09:54 AM
irocdan's Avatar
Car: 88 Iroc vert
yes i rolled the lips and no i had 275's on front
Old Mar 31, 2005 | 06:17 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
irocdan, Can you tell me your adapter specs and wheel offset are they 56(front)/50(rear) ones or the 38(front)/36(rear) ones. I plan on getting some ZR1's for my car soon.
Old Apr 4, 2005 | 04:08 PM
irocdan's Avatar
Car: 88 Iroc vert
2.25" fronts 1.25" rears 50mm rear i believe its the grandsport offset.let me know cuz i still have mine at home i might sell
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
