can the steering knuckles be replaced
Old Mar 25, 2005 | 01:02 AM
inuyasha_lost's Avatar
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
greetings everybody. i have had my 90 camaro for over a year now and have aquired some really nice upgrade parts for it. (LS1 block, 3.42 locking rear-end). anyhow, to the point. I HATE THE STOCK FRONT BRAKE SETUP!!!! So I was wondering if I could replace my current steering knuckles with the disc type. I hate having to re-pack the bearings. And when I go to buy new rotors I hate the price as well. Any tips, or deal with it? Thanks.
Old Mar 25, 2005 | 03:22 AM
Spdfrk1990's Avatar
Yah get you a zo6 setup ebmiller sells them or use to.
Old Mar 25, 2005 | 02:54 PM
any particular year range?
Old Mar 25, 2005 | 03:00 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
you have a few options, 1le, which is prolly the most expensive, c4, and ls1 (98-02) which all have 12" rotors and will fit under stock rims. you could also to c4 hds or c5 which 13" rotors, and some wheels will not clear.
you dont have to remove your spindles (its a good idea though), follow this thread:
https://www.thirdgen.org/techbb2/sho...ght=%2Bspindle
check out the brake board and the faq board for more info
and yes, pm ebmiller88, he can get you hubs and brakets for any of the swaps
Old Mar 25, 2005 | 03:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1LE has an integral hub and rotor, which is what he's complaining about.
Old Mar 25, 2005 | 03:35 PM
thanks guys. i don't want the spindle setup anymore. too annoying. so thanks for the tips.
Old Mar 26, 2005 | 12:27 PM
is it possible to upgrade the whole suspension to something where i could go to just front rotors (with no hubs)? or keep dreaming.
Old Mar 26, 2005 | 12:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't need to change the suspension to upgrade to a hub and rotor setup. Check the recommended reading above.
Old Mar 26, 2005 | 01:52 PM
ok, i do not want the hub/rotor setup. i want rotors only. there has to be a way w/o hubs. no hubs, i hate hubs.
Old Mar 26, 2005 | 01:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, you want a hub and rotor setup. Without a hub there's nothing to bolt the wheel to. You want a separate hub and rotor. What you don't want is an integral hub and rotor.
Old Mar 26, 2005 | 02:11 PM
so no way to change my steering knuckles then, oh well that's the answer i was looking for. thank you
Old Mar 26, 2005 | 02:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't need to change the steering knuckles.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
