Need tires
Car: 1991 RS
Engine: 305 TBI
Need tires
I have a set of 18x9.5 C5 wheels. I want to get 245-40-18 for the front and 275-35-18 for the rear. Is this a good tire combination? Also will the 275's be too wide in the rear and stick out past the fender lip? And are there any good tires that you guys recommend? Thanks in advance.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd go with a 275/40-8 in the rear. But thats me i like a taller tire in the rear. Right now your tire choice will have the larger diameter tire in the front.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally posted by Rossdaddy63
i thought 275-35-18's and 245-40-18's were both 25.7 inches
Car: 82 Z28
Transmission: TH350
275*.35=96.25mm
245*.40=98mm
So the difference in sidewall height is 1.75mm
Not much but its still a difference. Also since your putting a 245 tire on a 9.5" so the tread will be really stretched, making the sidewall even shorter. So actually it might look fine.
245*.40=98mm
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I say go with 275/40R18s, that's what I have. The ride is stiff and handles well, but there is no way I would go to a 35 profile on these. You won't gain any noticeable lateral grip (handling) and you'll lose even more straight-line traction.
Car: 1991 RS
Engine: 305 TBI
i'm eventually going to lower my car too, prob about 1/5 inches. aren't 275-40's 26.7 inches tall? Isn't that a little too tall? Would my drop still work with that?
Car: 82 Z28
Transmission: TH350
Your going to lower your are 1/5"? The rear of my car is lowered 1.5"-2" so it shouldn't be a problem. My front is so low, i can't get a jack of any sort under the k-member.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Also, some tires are skinnier with the same numbers.
My 275/40/17 Nittos and 275/40/17 Kumhos are Skinnier than my old 275/40/17 G-Force T/A KDW's.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
