17" & 18" wheels?
Old Apr 17, 2005 | 02:41 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
17" & 18" wheels?
I'm currently planning on running a wheel combo with 17" in front and 18" in back. My reasoning was for handling performance and looks (larger wheel in back for the "fat" rear end). Anybody see a problem with this combo? I know the 18" tires are more expensive, but any other problems/ideas come to mind?
Old Apr 17, 2005 | 03:02 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i wanted to do the samething too but i thought about, what if i want to rotate them. i couldnt cause the front would have the 18 and the back would have the 17.. i just like to rotate my tires for even wear.
Old Apr 17, 2005 | 07:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You won't have a problem. Most people run different size tires in the rear even if they stay with the same wheel size all around. Plus, many tires are unidirectional which eliminates one aspect of tire rotation.
Old Apr 17, 2005 | 07:54 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Ïn most cases people would have wider tires in the rear, so they won't be rotatable anyways.....
I haven't seen 17" and 18" But I think it looks sharp with big'n'little on some cars, not all. Can't say how a thirdgen would look though.
Old Apr 17, 2005 | 10:15 PM
A10Beav's Avatar
Engine: LS2
Rotation is a problem no matter what size rims I pick. I'm going with 245's up front and 275's in back, so I can't do a normal rotation. I was looking at assymetric tires so I can at least do a left-to-right rotation, there just aren't as many tires to choose from if I do that. I guess there are ups and downs to everything, I'll just have to think about it.
Old Apr 18, 2005 | 12:49 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I've got 17s in front and 18s in back ('97-99 C5 wide-spoke style), and they look great. A lot of people say these cars aren't designed for a bigger rim diameter in the back, but its hardly noticeable and looks good.
The problem with having a bigger rim in the back (if you want to stick with stock-height tires) is that you'll have less sidewall, which means less straight line traction and more wheelhop if you don't have the proper suspension setup. There's no way I'd go with anything less than a 40-profile tire in teh back.
I run 245/45R17 and 275/40R18. My rear tires are a bit taller than stock. Don't go with a 275/35R18. If you want a stock-height tire, go with a 275/40R17 (17" rim then).
If you're getting aftermarket rims, just make them all 17s. Only go the 17/18 route if you're getting C5 rims or something.
Old Apr 18, 2005 | 02:09 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm running the Corvette wheels also.
I'm using 275-40-17's front and 275-40-18's in the rear.
Tires are less expensive than I expected.
My car's lowered and they fit fine (with 2" adapters).
-Rich-
Old Apr 18, 2005 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There are 2 virtually identical copies of this post today already. Enough is enough.
A quick click of the button would have brought up this thread from just a couple of days ago; probably on the same page you put your new postings.
https://www.thirdgen.org/techbb2/sho...hreadid=290297
Try to ignore the bickering, and the stubbornness guy that's determined to make his car look like an Escalade; he got pretty offended when reality reared its ugly head and interfered with his fantasy. He REALLY didn't want to hear that what he wanted to do was a bad idea. But apart from all that, there's a couple of pics of cars in there to give you an idea.
Old Apr 18, 2005 | 04:00 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
just get 17s or 18s , dont starrar the sizes , the dont look good, i saw one in person and you can tell the rear is larger and doesnt look right to me. but its your car , so do with it what you want.
Old Apr 18, 2005 | 06:01 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
a10,why are you getting such skinny tires?
Old Apr 18, 2005 | 06:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Those aren't skinny at all and a 275 tire is typically the width used on 17x9 or 18x9.5 wheels.
Old Apr 18, 2005 | 07:04 PM
irocdan's Avatar
Car: 88 Iroc vert
true,but what size wheels uyou running in the front to use a 245?
Old Apr 18, 2005 | 07:06 PM
Car: 1997 Corvette
The ones he's going to use are 17x8.5, just like the ones I have. 245/45R17 came stock on Vettes for the front tires with this rim size.
EDIT: That's assuming he's using C5 wheels. Either way, they came with 8.5" wide rims up front wrapped with 245/45R17s.
Old Apr 18, 2005 | 08:13 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I run a 245 up front on a 9" wide wheel. It looks perfect. I didn't want to go quite as wide as a 275 because I was afraid i would have some rubbing issues.
Old Apr 18, 2005 | 10:59 PM
A10Beav's Avatar
Engine: LS2
I am planning on a 8.5 wheel up front, I currently run 245's and I don't see a need for anything bigger than that (anything bigger would be too tight anyway). I'll be getting 9.5's in back, I just have to decide the diameter.
DuronClocker, if you like your set-up, why don't you recommend those sizes if they're aftermarket wheels?
Old Apr 19, 2005 | 12:54 AM
Car: 1997 Corvette
Cuz I feel if you're getting aftermarket rims you might as well get them the same diameter. I don't think it looks cool to have different sized rims on these cars. Its just not very noriceable with my setup, so it doesn't look bad. You may as well go all 17s or all 18s if you have the choice. I love the look of my rims, but I got them as a set for next to nothing in a triangle trade. If I had the choice when getting them, they all would've been the same diameter.
Old Apr 19, 2005 | 10:19 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
18" wheels in the rear either make the dire diameter too large (275-40-18), or if you use a lower profile tire, the ride and handling are hurt.
I would suggest a 17x 9.5" (or 9") wheel all around with a 275-40-17 tire. Best of all worlds, just not the visual impact of an 18".
Old Apr 19, 2005 | 10:48 AM
irocdan's Avatar
Car: 88 Iroc vert
whatever you think looks good and works right without probs is a good thing
Old Apr 19, 2005 | 06:42 PM
Kandied91z's Avatar
anything in a 275 with 35 profile or higher really isn't noticeable. you would be fine with a 275/35/18.
Old Apr 20, 2005 | 12:15 AM
A10Beav's Avatar
Engine: LS2
thanks guys
Old Apr 20, 2005 | 09:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i seen a 17/18 inch wheel combo on a thirdgen from the side profile and it was obvious one wheel was bigger. didnt look good. do 18's all around or 17's if you want.
Old Apr 22, 2005 | 08:01 PM
Red92TA's Avatar
Car: 92 TA, 91 RS, 98 Tahoe, 95 S10
Engine: 305 TPI, 350 Vortec TBI, 350 Vortec, 4.3 Z
Transmission: 4L60, T-5, 4L60E, T5
I have the 17 front 18 rear set up, and it looks just fine. I went with the incorrect tires though. If you match your sidewall heights (not just the profile size), the difference in size is not noticable. Unfortunatly I bought front tires 4 months before my rears...and my rears have very low sidwalls (275/35) and the fronts are a little to tall (245/45). Next time around I will look for a 30 series up front if I can find them. Overall performance has not suffered with the short sidwall in back either.
Old Apr 22, 2005 | 11:02 PM
Kandied91z's Avatar
if you take the right picture it isn't noticeable... otherwise it's very noticeable.
Old Apr 23, 2005 | 10:30 AM
Car: 1997 Corvette
245/45R17 is a stock height tire on a 17" wheel. Ends up being 25.66" tall, which is the same as the 245/50R16 tires stock. 275/40R18 is a 26.66" tall tire, and 275/35R18 is 25.58" tall. Granted, these will all change a bit as they wear down. I'm probably going to buy the same 245/45R17 tire size next time but might increase the rear to something like a 295/35R18 if it will fit on a 9.5" rim. I wouldn't go with a 30 profile tire up front with 245 width....it'd make it look funny with too small of a tire up front. That's only 22.8" tall and it'd look incredibly funny.
Old Apr 24, 2005 | 07:27 AM
Red92TA's Avatar
I will see what I can do about putting a picture up...the difference in sidwall height is huge with the standard front and 275/35 rear.
Old Apr 24, 2005 | 02:27 PM
A10Beav's Avatar
Engine: LS2
Yea, a 45 in front and 35 in back is a big difference. I'm planning on 45 in front with 40 in back, that's the stock C5 set-up and it looks/drives good.
Old Apr 24, 2005 | 02:43 PM
Car: 1997 Corvette
245/45R17 and 315/35R17 have the exact same sidewall height...
A 275/40R17 also has the exact same sidewall height..
Old Apr 24, 2005 | 04:09 PM
Kandied91z's Avatar
just use a tire calculator and try to get close to your factory specs. if you get it within a .25" you'll be fine, everything else you'll notice. play with widths and sidewall sizes til you get it right.
works everytime..
http://www.miata.net/garage/tirecalc.html
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
