track bar brace bolt
Old May 1, 2005 | 05:06 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
My track bar has some play in it at the pass side through-bolt. I can hear it banging when I shift. I cant seem to tighten it up any. Does anyone else have the same problem? What makes it worse is the noise from the heat shield when it bangs.
As far as I know, there is no bushing, just a steel sleeve. I cant move it back and forth but I can twist it slightly up and down. I'm afraid that the bolt holes in the brace have elongated a bit.
Old May 2, 2005 | 07:59 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
umm track bar? don;t think i got one of those, whats it look like?
you may mean the torque arm from trans to rear... panhard across rear end, lower control arms on frame to bottom of axel, sway bar liknk on sway bar to body mount thing...hahah thingamagigger.
let us know what part
jeff
Old May 2, 2005 | 09:58 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Track bar=panhard bar
Old May 3, 2005 | 02:28 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
panhard bar brace. pretty sure its just a metal sleeve, no bushing. could prolly find one somebody is willing to give away, worth a try
Old May 3, 2005 | 09:24 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have this same problem, but I have an adjustable panhard that should be home when I get there tonight. That's how I'm fixing it.
Old May 3, 2005 | 09:23 PM
KagA152:: Yeah...I think i just need to pull that bolt out and see exactly whats going on. Everything else in my rear susp in boxed or tubular so the track bar brace is currently the weakest link.
If the bolt holes in the brace have elongated I'll just get another brace at a salvage yard or buy the boxed aftermarket one.
I need to clarify for some of you guys in this post that I'm talking about the panhard (i.e track bar) brace. It links the panhard bar to the body.
Old May 3, 2005 | 09:43 PM
Car: 91 Camaro RS
Sorry I thought you were talking about the panhard bar (body to track bar) not the track bar (body to panhard). I would check my bolt was smaller for some reason which let to the hole becoming elongated.
Old May 7, 2005 | 11:55 AM
Well....I went to the salvage yard and picked up a 4th gen track bar brace and just for the hell of it boxed it in and painted it. On the install I used rubber bushings between the heat shield and track bar brace.
But that is the MOST stupid bolt ever. It tapers down on one side so its a one way application: the threads have to face toward the rear of the car. So there is some play between the brace metal sleeve and the tapered end of the bolt. But there isnt much you can do about it except reallt crank on the bolt during installation to get it as tight as possible.
I got a H/D servo in my trans a few weeks ago. Every time I hit 2nd gear hard I hear a knock in the pass side rear. I think its due to play in the brace. I dont know.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
NBrehm
Aug 5, 2015 07:57 PM
