2" spacer still needed with 9" wheels vs 9.5"
Old May 10, 2005 | 11:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I am getting some ZR1 wheels and want to know if I still need the standard 2" adapter as most use wth a 9.5" rim. I don't want the rim to stick out past the fender in the front. The rear I dont car much. What shoulld I do fellas? Will a 1.5" work?
Will
Old May 11, 2005 | 06:10 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
all depends on the backspacing
Old May 11, 2005 | 10:01 PM
norcalz28's Avatar
GM ZR1 wheels, 9" wide, 40mm backspacing is what I am told. Prolly go with a smaller tire than 275 to avoid rubbing. But what spacers do I use??? Come on guys, I know someone has done this before with SUCCESS!!!
Will
Old May 13, 2005 | 02:53 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
ive only seen them in 9.5 im running 2 1/4" adapters
my ride looks perfect
Old May 13, 2005 | 02:56 PM
norcalz28's Avatar
GM camaro wheels as seen on SS's from 96-99 feature 9" wide ZR1 rims. But it seems that a 2" space will do just fine. Thanks
Will
Old May 13, 2005 | 04:50 PM
irocdan's Avatar
Car: 88 Iroc vert
afs wheels in canoga park have the gm mold. superior wheel used to make them for chevy.so the wheels they sell are from the actual molds www.afswheels.com 818-340-6181
Old May 15, 2005 | 06:23 PM
Marc 85Z28's Avatar
I've got GM 17x9s with 2" spacers and IMO they're ideal for the application. 1.75" might tuck a little better, but may cause tire rub. I DO NOT recommend 1.5", as the wheel will likely contact the tie rod end.
Old May 16, 2005 | 01:36 AM
norcalz28's Avatar
Right, but most aftermarket manufacturers seem to favor the 9.5" width. I don't think I have seen anyone make a repro GM SS wheel.
Marc, thanks for the info. I would like to maybe try the 1.75" in front. I would like the front to be a little more tucked than the rears. Do you have any pics of yours upclose? I would love to check it out
Will
Old May 17, 2005 | 05:35 PM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
HEy man, I am running Y2K wheels 18 x 9.5" on all 4 corners and I am running 2.25" in the front and i have a 99 Z rear and I have no issues with rubbing. Also, I have a set of 1.75" and 2.25" I am trying to get rid of, PM if you want them, I need to get rid of them! I believe they are the vette brakes adapters.
Old May 17, 2005 | 06:56 PM
Marc 85Z28's Avatar
This is about the best I can do
You can see that the fronts tuck nicely. Again, 1.75" may work, but I can tell you for sure that the 1.5" will not fit. Contact Andris Skulte from Skulte Performance for more info on the 1.75" fitment.
customblackbird
Aug 15, 2021 10:16 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
