Sub-Frame Connectors
Old May 11, 2005 | 12:43 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Do you guys recommend the bolt on, or weld on subframe connectors?
Old May 11, 2005 | 12:54 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I recommend weld-on SFC's.
The bolt-on varieties will eventually elongate the bolt holes where they are attached.
Old May 11, 2005 | 07:55 AM
kevinc's Avatar
Car: 1982 Z28
Weld on, and welded not only to the front and rear locations but also along the rocker panel seams.
With South Side Machine SFCs they're close enough to the rockers that they can be welded this way, and it really tightens the car up.
Old May 11, 2005 | 03:46 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go ahead and buy the bolt on SFC's and then expect some new rattles. Welded is the only way to go.
Old May 11, 2005 | 04:33 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
The general concencus(as i see it) is that Spohn subframe connectors are the best buy.
Old May 11, 2005 | 05:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Dont forget bolt in's can be welded after you bolt them up in the car, heck I dont think i'd even try to get the bolts into a set of alstons, but they weld in great.
Old May 12, 2005 | 01:25 AM
Car: 91 Silverado
Do you guys treat the welds for rust, or paint them or something?
Old May 12, 2005 | 06:45 AM
DJP87Z28's Avatar
Yes. paint the welded areas.
Old May 12, 2005 | 07:46 AM
kevinc's Avatar
Car: 1982 Z28
POR-15 baby!!
Old May 12, 2005 | 10:44 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I did both. Bolted them in at home, then drove to the muffler shop and had them weld em up for me....
Old May 20, 2005 | 03:50 PM
CaysE's Avatar
Have the car professionally straightened at a frame or body shop, then get SFCs welded on.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
