Should I cut these Drop zone springs
Old May 25, 2005 | 03:22 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I was thinking about taking them off the car and cutting them a bit but i'm not exactley sure if I should or If I do, how much should I cut. I would like to go 2 inches lower in the front and 1-1/4 lower in the rear. The fronts are so high in this picture because their v8 springs and I have a v6. What do yous think? Just cut 1/4 of a coil and call it a day no matter the results. It would be too much of a hassel to put springs on , lower the car down and look, then want to lower more and take them back out.
Old May 25, 2005 | 03:56 PM
semiller26's Avatar
Car: 1986 Trans Am
why don't you just wait until you put you V8 in since you think the problem seems to be the lightweight V6.
Personally I wouldn't wanna have it too low after the V8 goes in and have to redo it.
Old May 25, 2005 | 04:21 PM
Car: 2002 SS
Engine: Ls1
car show is june 11 & 12th and I don't think it looks right. I won't have the v8 in before the car show so I don't know. When I put the v8 in i'll probably get intrax drop since it's lower then the dropzones.
Old May 25, 2005 | 06:04 PM
semiller26's Avatar
Car: 1986 Trans Am
even the back seems high and it shouldn't make a difference like it would in the front. Did the overall diameter of the tire change? It it were me I'd go to the yard and get some cheap V6 springs and cut those. Just cuz I'd be easier for me to sell the dropzones later if I'm gonna change them out.
Old May 25, 2005 | 07:47 PM
Car: 2002 SS
Engine: Ls1
See if I cut stock springs they would bounce and my car may bottom out, which isn't good at all. It won't be that much of a loss because I got a deal on these springs since they were used. I wish I new how much to cut to lower 2 inches and the rear to go down 1-1/4. I would hate to cut and fit cut and fit etc.
Old May 25, 2005 | 07:49 PM
Car: 2002 SS
Engine: Ls1
I have V8 springs with a V6, that's why the car is sitting higher up front then in the rear.
Old May 25, 2005 | 08:00 PM
semiller26's Avatar
Car: 1986 Trans Am
depending on the springs you get about an inch or so per coil. If they are progressive springs though cutting them can screw up the spring rate.
Old May 25, 2005 | 08:43 PM
Car: 2002 SS
Engine: Ls1
Well i just did alittle research and saw this guy with a v8 cut a half coil off and the front tires were tuckin. So i'm guessing like 5/8 of a coil in the front since i have a v6 and 1/4 of a coil cut in the rear?
Old May 26, 2005 | 06:36 AM
Car: 2002 SS
Engine: Ls1
or you think thats too much?
Old May 26, 2005 | 02:24 PM
semiller26's Avatar
Car: 1986 Trans Am
better to cut too little that too much i'd just go slow until you get it right
Old May 26, 2005 | 07:41 PM
Car: 2002 SS
Engine: Ls1
that would take a long time
Old May 27, 2005 | 04:43 AM
semiller26's Avatar
Car: 1986 Trans Am
as opposed to getting in wrong and having to start over i guess.
Old May 27, 2005 | 06:43 AM
Car: 2002 SS
Engine: Ls1
true true, so i guess i should start off by cutting 1/4 off of the spring first then mock fit?
customblackbird
Aug 15, 2021 10:16 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
TA8487
Aug 11, 2015 09:02 PM
