Competiton Engineering ''Weld-In'' subframe connectors
Old Jun 6, 2005 | 05:27 PM
Big_C's Avatar
Car: 1989 Firebird
Engine: Custom 355 V8
Transmission: TH-350 with 3000 converter
Hey guys, I'm shopping around for subframe connectors for my 89 firebird. I know I want to get weld in ones. I was looking at the Competiton Engineering ''Weld-In'' sfc's and in the discripition its says something about " modification to floor pan is required" What modifications are needed? Is it just a simple bump that has to be cut or pounded out, or am I going to spend hours cutting and welding my floor?
Also if these sfc's are no good, which ones would you recommend?
Any help would be great!!
Old Jun 6, 2005 | 10:23 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Check out Spohn's. His products are top notch. Also check out the rest of the sponsors listed at the top of all thirdgen.org webpages. You can find almost anything you need (thirdgen related) from them.
Old Jun 7, 2005 | 08:05 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
In order to make the CE ones work you need to cut about a 1'x1" strip for them to tuck into the floor pans on both sides. Personally I would not go this route. Definitely look around. There are many sets out there that require no modification to the car other than welding.
Old Jun 7, 2005 | 08:43 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I have the weld in CE's and they required no modification at all. They tucked up nicely into the chassis. I looked around and found these square tubing ones to the beefiest out there.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
