Old BMR adjustable pandhard question.
Old Jun 12, 2005 | 03:26 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Hey,
I just put my aquired BMR panhard bar in and need to adjust it. It's the old style with screw in bushings at each end with lock nuts. No center adjuster.
It seems the lock nuts are locktighted, and I was just curious if anyone knew if they were standard threads at each end? I would hate to try and loosen one and wind up tightening it..
Kevin D.
Old Jun 12, 2005 | 03:49 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
As far as I know, one should be a right handed thread and the other left handed. It is just a elaborate turn buckle.
Kat
Old Jun 12, 2005 | 08:28 PM
shr00m's Avatar
That was it! I assumed that since mine didn't look like the current ones it had to be adjusted off the car.. I just backed off both nuts and turned it by hand.. Took a while to figure out which side was reverse thread though...
FYI, the side that has the nut shaped spot in the tube is the reverse thread side..
Kevin D.
Old Jun 12, 2005 | 08:31 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Yep that is the left handed threaded end
Good job
Kat
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
