Is this a myth?
Old Jun 14, 2005 | 09:08 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Is this a myth?
I understand the argument for having the chassis weight on the suspension when installing SFCs and it makes sense, but I'm not convinced.
I have the car stripped down to the shell right now and I'm thinking, "perfect time to install SFCs." Is there any proof that installing them in this state would be inferior to having them installed when I get the rolling chassis together with a drivetrain and proper weight?
Old Jun 14, 2005 | 09:53 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I'm not sure what you mean by "proof"? Difference in corner weights? Seat of the pant guess? Doors lining up differently?
Every chassis has some flex in it, no matter what, and most race cars are gutted when installing cages, so you are either stiffening the chassis before it flexes, or after. Conventional wisdom says to have the car loaded on the suspension equally, but as long as you don't have the shell twisted (i.e. on two jackstands on the drivers side, and only one on the passenger side), it should be just fine. Try to keep the way the car is loaded symmetrical. If it's got wheels on it, an open deck trailer is a very easy way to get under to weld the SFC's.
Old Jun 14, 2005 | 10:07 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm not sure the engine would need to be in it. But a rolling chassis would be highly advised.
Old Jun 14, 2005 | 12:38 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Well, one plus if you did it at this state would be no carpet or anything to catch fire inside, the other would be no fuel in the lines if it's just the body.
I personally believe for you to benefit putting them on at this stage, you would have to make sure it is completely squared, then it might make a difference.
Old Jun 14, 2005 | 06:49 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Just make sure that it's not twisted or flexed. As in lifting one wheel off the ground does.
Old Jun 14, 2005 | 09:42 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Thanks for the replies.
I still find it hard to believe that there would be any difference at all. Whether the car is all together and on a drive-on style lift sitting level or I just the shell, still supported from the areas where the suspension normally lies, there is still at least around 2000 lbs. being supported.
I have a nice 6 ft level I can use, so I'll make sure the two front and two back frame rails are level before I do anything.
Old Jun 16, 2005 | 12:18 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
so having the rear axle on 2 jackstands, and the front wheels on ramps is ok for welding these on? I still haven't installed my SFC's because i honestly wasn't sure how.
Old Jun 16, 2005 | 05:04 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
As long as the car is sitting level from left to right then I would say that's fine. It wouldn't matter if the front is higher or lower than the rear.
Mark.
Old Jun 16, 2005 | 08:48 AM
Mark.
+1
As long as it is sitting level or near level.
maroe624
Apr 16, 2017 08:29 AM
InfinityShade
Feb 21, 2016 01:29 PM
GWW
Aug 13, 2007 10:06 PM
safemode
Nov 14, 2005 08:39 AM
TraviZ
Oct 31, 2004 03:13 PM
