car leans
Old Jun 20, 2005 | 12:52 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
car leans
Has anyone had problems with there car leaning? Mine is leaning towards the passanger side. The right rear fender is 1/2 lower then the left rear. The car is on level ground. I have drop zone springs, new shocks, adjustable panhard bar. Is it posible to have a bad shock that could cause it. Cause when I put the new shock in I was questioning it to begin with.
Old Jun 20, 2005 | 12:56 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
oh and I dont have the rear sway bar installed.
Old Jun 20, 2005 | 01:20 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Probably just heavier on the passendger side, you do have the spare and everything in that quarter panel.
Old Jun 20, 2005 | 01:42 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Did you index the springs?
Old Jun 20, 2005 | 11:08 AM
CaysE's Avatar
I doubt that the shock would affect this, it's usually springs or endlinks. If one of your springs is indexed incorrectly, it will sit lopsided, so recheck everything. Alternately, if one of your endlinks is broken, that could cause a slight lean in the car as well.
Old Jun 20, 2005 | 12:15 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
What do you mean by indexing the spring
Old Jun 20, 2005 | 01:44 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
adjustable panhard rod?
Old Jun 20, 2005 | 03:09 PM
phoenix305's Avatar
On the front springs the end of the spring has to sit inbetween the two holes in the back of the a arm. Other wise it will sit lope sided.
Old Jun 20, 2005 | 04:23 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Re: car leans
I bought my car and it had been sitting for probably 7-10 years. Both rear shocks were probably shot, but one was leaking and it was apparent...when looking at the car from the rear you could tell that the car was leaning.
The new shocks cured this.
Old Jun 21, 2005 | 01:56 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Yes I have an adjustable one. I am going to warrnty out the one shock I was questioning. Also there were no aperent grooves that the spring sat in except the isolators and they are sitting right
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
