Camber Caster Plates Camaro Firebird 82-92
Old Jun 21, 2005 | 08:32 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
saw these on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
has anyone used something like these? good, bad???
Old Jun 22, 2005 | 12:01 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I just e-mailed them and got a call back.
I talked to Brian and he said that they're height adjustable off the strut tower with aluminum spacers and that the plate itself is 5/16" mild steel. He also said that they've changed their bearing design from what is pictured. It's actually 4 bolts holding it now to keep it more rigid.
They based the design off their Mustang parts when they saw the need for F-body pieces. He said they've got a few guys using them on Camaro-Mustang Challenege cars so I'd say they must be pretty darn strong to withstand the abuse those guys put them through.
Thanks for posting the link, I've been half-*** looking for a pair and this price is killer. I asked if they had a racer price and he said the ebay price is a lot better then what they usually go for which is ~$180. He also said that he's not sure if they'll be relisted on ebay since the response hasn't been as good as they hoped.
Not sure about anyone else, but I'm going to pick up a pair.
Old Dec 12, 2005 | 05:57 PM
CMC#79's Avatar
What brand were these?
Old Dec 12, 2005 | 06:46 PM
nape's Avatar
Hot-part.com is the vendor.
I ended up having a small problem with them but the owner did offer to take a look. I had to store the car before I could take pictures.
The problem is that the driver's side plate hits the master cylinder at over -.5* camber if you run both spacers on top of the strut tower. Moving one spacer under the strut tower fixed the clearance issue.
The customer service was great though. I'm confident that I'll find out what I'm doing wrong or a fix when I pull the car out in the spring.
Old Dec 16, 2005 | 05:07 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I installed them but w/o the spacers.
Old Dec 16, 2005 | 05:34 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yep that we did.. BUt when the struts go in I am going to figure out what size spacers you'll need to get the proper strut travel.
Old Dec 16, 2005 | 06:18 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
I've been running these on my CMC car. Great quality and zero problems. Kudos to Brian and everyone at Hotpart.com!
Old Dec 16, 2005 | 11:32 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Thanks dood!Glad one of us knows what the hell the're doing.
Old Dec 18, 2005 | 05:03 AM
83 Crossfire TA's Avatar
huh, what happend with the ebay ad (for that matter, i can't find any similar listings either)?
Old Dec 18, 2005 | 07:25 AM
bjm323's Avatar
Car: '91 Camaro RS
I think these are the ones they are talking about Crossfire.
Hotpart caster camber plates
Old Dec 18, 2005 | 03:17 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Yep they're the one's that I'm talking about
Old Jul 17, 2014 | 10:48 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: Camber Caster Plates Camaro Firebird 82-92
are these guys gone ??can't seam to find them
Old Jul 17, 2014 | 12:42 PM
nape's Avatar
http://www.hotpart.com/camaro-firebi...-black-or-red/
1992 Trans Am
May 10, 2023 07:19 PM
89lsc
Aug 14, 2015 04:58 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
