think i have a small problem
Old Jul 4, 2005 | 07:17 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
heres the deal. i just put in a PA Racing tubular front crossmember and spohn tubular A arms and i also have eibach springs. the problem is that the car just about sits on the ground. i deffinately cant drive this thing like this. has anyone ever had this problem before. is there something else that i had to get. if i put the stock springs back in do you think that the front end will go up. here are some pics of it.
this is how the car use to sit with the eibach spring, factory crossmember, and factory A arms
Old Jul 4, 2005 | 08:34 PM
kevinc's Avatar
Car: 1982 Z28
I haven't tried PA or other aftermarket crossmembers or A-arms, so not much help there...given the difference in ride heights it's a safe guess that the geometry is different.
I have a few other spring sets here in Randolph if you want to borrow and test. Moog 5662, 5608, and a set of aftermarket 800# on the shelf.
Old Jul 5, 2005 | 04:06 PM
Car: 84 camaro Z28
Engine: 434sbc
im going to try the factory ones and see if it makes any difference. but if it doesnt i might take a trip down to see what you have(if you don't mind)
Old Jul 5, 2005 | 04:15 PM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
Transmission: Probuilt 700R4
I think it looks great!
Have you tried driving it? Are you having clearance issues?
Do the tires rub lock to lock?
You definately filled the wheel wells without having to go up in wheel size.
I might have to give that mod a shot..way better stance than I currently have with just the eibach pro springs.
Tuck
Old Jul 5, 2005 | 04:24 PM
Car: 84 camaro Z28
Engine: 434sbc
im more worried about ground clearance than anything else. the crossmember sit about 3 1/2 inches off the ground. and the bellhousing is about 3 inches off the ground. with the car the way it is now, i highly doubt that i could get in or out of my driveway.
Old Jul 5, 2005 | 04:40 PM
jetucker00's Avatar
Car: 89 Iroc Vert
Engine: A Loud one!
I guess I will need to measure where I am at right now.
It is probably sitting lower than that picture is showing.
I was just looking at your wheel wells when I read your post.
Ur right, 3.5 inches doesn't leave much room for even a driveway entrance let alone a speed bump.
Tucker
Looks good though!
Old Jul 6, 2005 | 07:43 PM
Car: 84 camaro Z28
Engine: 434sbc
well i guess i made some progress. i put the factory springs in and i gained 1 inch. i only did the driver side today. i measured from the ground to the bottom of the ground effect right behind the front tire and i now have 8 inches. it was 7 inches. does anyone have the factory measurement. it is such a pain in the *** to get the springs in. im using an internal compresser but you can only compress it a certain amount(which of corse is not enough) because the thread rod will hit the frame and you wont be able to get the spring in. that and the spring keeps hitting the tube that goes between each bushing on the a arm. that makes it extremely difficult to install the spring. i gess im going to have to deal with it because its to much of a pain to keep switching springs. it took me about 2 hours to do one side and it was a two man job getting that spring in.
Old Jul 6, 2005 | 09:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I think it looks perfect. My crossmember is about 3" off the ground...
jhawkeye
May 25, 2022 06:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
theurge
Aug 21, 2015 12:46 PM
