Torque Arm questions
Old Jul 7, 2005 | 09:13 PM
DotTC's Avatar
Car: 1984 Camaro Coupe
Engine: 2.8 v6
When I bought my 84 v6 Camaro it had no transmission in it. I've gotten everything hooked back up and back together. Except the torque arm. I was wondering if anyone could etail hooking this thing back up, and what would problems would I run into if its not hooked up? Any help would be GREATLY appreciated.
Old Jul 7, 2005 | 09:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Two bolts mount the torque arm on the differential, and the front slips into a rubber bushing in a clamshell type of mount bolted to the tailshaft housing of the transmission. You need a torque arm, it's the only thing keeping your differential from rotating.
Old Jul 7, 2005 | 09:25 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Not all stock arms are stamped the same way. Not quite sure how to explain it but some face one way and some the other.
Old Jul 7, 2005 | 09:34 PM
DotTC's Avatar
Engine: 2.8 v6
I seem to have lost(actually the ppl I bought the car from lost) the clamp part that bolts to the transmission, how much should I expect to pay for this part? and would ebay or a jyard be the easiest place to get it?
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use the right bushing in the front and it won't matter which you have.
A junkyard would probably be easiest.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
